What I'm stuck on picking is the amp...
which one of these would you get?
Audison SRx 3
Load Imp.| 3 Ch
4 | 2x75w + 1x270w
2 | 2x95w + 1x350w
or Digital Designs C4
4 ohm 100W x 2ch + 200W x 2ch
2 ohm 150W x 2ch + 300W x 2ch
Edited by -=MC=- Coolio
Westside car audio sell hertz, audison and my favourite "Focal" personally i would go for the jl audio 12" w3v3 sub, only 300rms but when you hear it...ouch sounds more like a 400+rms sub!
and yeah if you have the money your heading the right way with the amp, cant go wrong with audison!!
i bought a pair of the hertz split speakers and generally if i had the extra 120 i would get the focal.
westside car audio's website isnt up at the moment, is there any other places to buy the parts? I need an online store where I can get the speakers delivered to my door.
And have decided my complete setup!
  • Source Unit: Clarion DXZ666MP
  • Front Speaker: Hertz HSK165
  • Amplifier: Audison SRx3
  • Subwoofer: Hertz HX300
  • Cable: Audison Connection
  • Deadening: Dynamat
    Can get it all for around 2 grand at FHRX studios, so will shop around and see if i can find better.
    I need a place to buy it all at!
Why does it have to be an online store?
Most shops will do mail order to ur door.
And that package is outdated. The Clarion headunit is now obsolete it got replaced at the start of the year with the DXZ676USB
Edited by Adelaideprosound
Oh, ok. Mail order is fine. So is anything else in need of updating or is the rest of the list ok?
I have these spilts: Hertz HSK165 and i love them.. plenty of mid bass too!!
Anyways i dont think marty (FHRX) has updated that section..
But apart from head-unit.. Rest all seems fine for what you will need
Go with the hertz spilts.. Audison Srx3 amp- sub of your choice to handle around 300rms..
Sound deadend your doors, and you will love it..
Edit: just read your above post
You will love this sub!! i have heard it personally and they go deep.. just make sure you get your box done right
If you dont like the sub i will buy it off you hahahah..
always wanted this sub.. but spending money on go fast bits lol..
i should really finish my audio off uh
ALso - MC -Coolio ---- Tell marty Sidd from SAU (with the one with the silver s2) sent ya.. tell him hes the person who keeps tellin him i will get my doors deadend!! he will remember.. hahah
On his website theres a specials page.. check that out for cheaper prices dude!!
Edited by siddr20
So you saying I should get a custom box done? or should i just buy a hertz box to go with the sub?
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
