I bought a used 3000km old Tomei fuel pump for my r32gtst.
Looking at the Tomei site it appears to be the correct one, part no. 183001 but this part no. isn't on the pump.
I was a bit surprised to see the Nissan emblem on it even though I didn't really expect to see Tomei on it.
post-13288-1192264845_thumb.jpgpost-13288-1192265117_thumb.jpgpost-13288-1192265280_thumb.jpg
It's marked Unisia Jecs A42-621B70
I found a pic of a bnr32/Z32 fuelpump and I can actually make out the same model no. on it.
The R32gtst Nismo pump is the same also.
It seems as though they are all the same pump so I don't care if mine actually came from Tomei or not.
My only concern is how it fits up.
The Tomei kit doesn't come with the clamp or extra regulator thingy that can be seen in the first pic but they were there in the bnr32/Z32 pics.
Are they needed for the r32gtst?
The Tomei kit comes with a spacer and cushion and I did not get these with my pump.
Do I need them for a drop in fit?
Can someone please shed some light on this?
https://www.sau.com.au/forums/topic/189139-tomei-hcr32-fuel-pump/
Another thing that puzzles me is if the tomei gtst pump is the same pump as a std gtr how come they rate the tomei gtst pump at 248L/hr and rate the std gtr pump as 195L/hr?
r32 gtst tomei pump: http://www.nengun.com/tomei/fuel-pump-niss...yline-r32-gts-t
r32 gtr tomei pump: http://www.nengun.com/tomei/fuel-pump-nissan-skyline-r32-gtr
Maybe they just look the same.
Does anyone know the model no. from the tomei r32 gtst pump for certain?
i have bought a few TOMEI pumps over the years and have one in our current S13/26 and it definately came with reg/damper and all associated mounting hardware.
I'm now pretty sure my pump didn't come from a tomei kit.
From the gtst nengun link in my last post it appears the tomei kit doesn't contain the regulator/damper thingy that came with the pump I bought. (Check pic in first post)
Tomei obviously don't think it's needed.
What does it do?
My pump didn't come with the cushion and spacer seen in the tomei kit.
I've ordered the cushion from Nissan as a genuine gtr part.
I think the spacer is made by tomei as a gtst adapter so I guess I'll have to make my own.
  • 3 weeks later...
Given that all evidence points to the r32gtr pump and the tomei gtst pump being identical why are they rated differently?
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
