MTQ mate there in adelaide heres the add number etc im getting my turbo lines thru them so go give em a call
Adelaide 7-9 Opala St Regency Park, SA, 5010 Ph: 08 8243 2688 Fax: 08 8243 2727 [email protected] [email protected]
Cheers
Allan.M
https://www.sau.com.au/forums/topic/189158-turbo-lines/#findComment-3411536
what so you show them what you got and they make em up?
Yeah mate $60 a hose or so.
just tell them the specs etc water cooled oil cooled how long you want the hose give them a call they can help alot more with the answer you require.
Cheers
Allan
Edited by R334door(s2)
https://www.sau.com.au/forums/topic/189158-turbo-lines/#findComment-3413037
Dude Will give you a hand and help you fit them not that hard. Ben 0400 299 897. Have my own work shop.
will ya put my turbo on for me pm-me to work out a price and sme beers :P
hey if i get the turbo put on first on a stockish r33 and stock ecu will it still run ok az long az i dont boost ittoo much??
sorry for getting off topic.
Anyway picked my lines up on tuesday great quality came with fitings and a hose to join my water lines together for kkr430
got charged $ 90 for everything if u send me ur mobile number i can take sme pics and show ypu if ya want?
https://www.sau.com.au/forums/topic/189158-turbo-lines/#findComment-3422875
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
