Hi all,
I remeber a thread about a week ago about ABS. Now someone mentioned an ABS light on the dash.
I have a 96 SII GTST, which apparently has ABS. On the Japanese auction report mentions ABS, etc, etc.
Now, i have no ABS light i can see come on. I have HICAS, ENGINE, Etc, etc.
Is there any way I can check if it has abs without slamming the breaks on while driving? anyone got a photo of the abs module in the engine bay?
Cheers,
Ace.
https://www.sau.com.au/forums/topic/18918-abs-again/
ABS module is on the right near the top of the firewall. Its a big metal thing with lots of little metal pipes going into the top. I only just found out what it looked like the other week myself, as mine is a series1.
There is also a control computer under your centre console glovebox
https://www.sau.com.au/forums/topic/18918-abs-again/#findComment-397323
  • 4 months later...
Sorry to resurrect an old thread but can someone provide a picture of the ABS module?
I don't have an ABS light on the dash but in the fuse box under the bonnet i have the 2x abs fuses plugged in - Just wondering if this car has ABS (1995 s1.5 (i think) R33, driver airbag, higher wing etc) but maybe the dash has been changed at one stage?
Or in non-ABS cars, do they just give you the ABS fuses cause they are feeling generous? :)
I might have to slam on the brakes to see if they lock up but I guess if I had a picture of the module I can visually inspect whether ABS is there or just spare fuses plugged into the ABS slot
Thx
https://www.sau.com.au/forums/topic/18918-abs-again/#findComment-581169
Hay mate, it also same happan to me, my car 96 GTST also doesn't have ABS as well.
If u wanted to know whether u have ABS or not , u can take ur car to the garage to ask. Or try it by urself, simply drive about 60Kms, and then totally stop the car, repeat it fews times. If the wheel didn't knock while u were braking. Then u has got a ABS. But if ur wheels is locking, that mean u doesn't have ABS. Hope it could help.( If i'm wrong, plz correct me!)
Cheers
Steven
https://www.sau.com.au/forums/topic/18918-abs-again/#findComment-581328
there's really an easier way guys....just pop your bonnet and have a look.......look for the ABS module similar to the one cobo_11 posted...it'll be in the upper right corner of the engine bay:D
https://www.sau.com.au/forums/topic/18918-abs-again/#findComment-581342
guys as everyone here has seemed to mention...just pop ur damn hood up and see if u have a big metal block with 4 or so pipes commin out in the upper l/h corner of ur car. or just look at ur firewall at the back of the engine block...if u have two small metal pipes runnin along there then u dont have abs...but if u have 4 then u have abs...now all u have to do is follow these 4 pipes that will lead u to the big metal block which is the mysterious abs module thingy mah jig that no one can seem to find. go out now and have a look before u forget:D:D
https://www.sau.com.au/forums/topic/18918-abs-again/#findComment-581351
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
