What Rb26 Turbos Do I Have?
Ramius83
 Share
What's up mates. I recently had a rear turbo grenade on me about 4 months ago while driving to work one day on my R32 RB26DETT engine. Well, I had a bloke that bought an RB26DETT engine from an importer here in the States. The engine was slightly modified, having wire taps on the harness, aftermarket FPR, R34 valve covers, etc. Anyways, I ended up buying his set of turbos from him. I was in the middle of installing them when I noticed something peculiar about them. On my stock turbos, IN A/R is 0.42 and the EX A/R is I think 0.48 if I can see my pictures clear enough. Well, the "stock" turbos I bought from my friend are different. They read IN A/R of 0.60 and EX A/R of 0.64. Side by side they are obivously larger, especially on the turbine side. Judging by what little research I did, I am thinking they are N1 turbos, but I am not sure, and if they are, I am not sure from what chassis, ie. R32, R33, or R34. I went ahead and installed both of them anyways. I feel like I am making a little more power at the same boost level of 13lbs, and it is of course taking a wee-little bit longer to spool. I have taken a few photos and I am wondering what you think. What are these turbos and what max PSI do you think I can run on them? Thanks all.
Edited by Ramius83
dude they look exactly the same as the pair of N1 turbos i fitted to my gtr,
check the spacing of the oil drain flange bolts,
the genuine n1's are the same as stock, R34 n1s are slightly wider bolt spacing, only 5mm but different.
Well, I used the drains from my stock turbos because he gave me his turbos with no components on them, ie. actuators, drains, line feeds, etc.....
Look at the plate in between the cooling lines on the center housing. There should be a plate with the part number. I have a set simular to yours. The numbers on mine are 14411-06U00.
Information I have found is these are R32 Nismo type turbo's with a 15 degree cutback and a 270 degree thrust bearing. They are supposed to be capable of about 300ps each. As for Maximum boost, cannot help you there. I do not think you would want to go as high as ball bearing equivelents.
 Share
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
