Yes it will hold it at 10psi, even WITHOUT a boost controller.
A boost controller will on increase from the base level of whichever actuator you are using.
Like the R33 which is 5psi, and then the boost solenoid gets it up to 7psi.
Therefore, if you only switch the actuator, it will go from 10psi low revs to 12psi when the solenoid kicks in at 4500revs.
im in the midst of putting the r32 actuator on my car now. it is a direct bolt on and if u only want it to run the actuator pressure u just run a hose from the actuator to the cooler pipe nipple and thats it yeh? so it will be 10psi? i dont wanna run 10 then 12. stock turbo would prob go knowing my luck.
gttr34 not sure if they are interchangable with the 32 actuator. if ur in melb ur more than welcome to see if my 33 actuator fits your 34. if it does, well the the 32 actuator will fit too.
Hey dude, i know im off the topic but cuz i just read ur mods and saw the high flow panel filter, does it make a nice loud woosh sound just like the pod style air filters???
mine makes the induction noise only coz i have a few 1.5inch mesh holes cut out around the lid of my air box. personal mod. it still allows extra air into the box while mainting its approval to the epa and allows induction noise.
Edited by cheez
Might aswell get a pod I guess cause your still going to suffer from heatsoak I believe.
its not that bad, i dont feel any difference from having a pod and having my airbox with duced holes. at the end of the day the box is probably better as it still has the front duct on so takes cold air in majority of it, from the front. and also, cops cant touch the car as the airbox is epa approved even with my mods to it.
How about for GTT R34's?? Will i be able to use the 32 actuator on the GTT R34? And if i do how will the boost stages and etc work out to be?
I've installed one on my R34. You'll run approx 12 PSI and it's a direct bolt-on, no modifications needed.
Edited by ztune_R34
i put a r32 actuator onto my r33 and it went straight to 15 pound not good on stocl turbo and ecu no matter what i did i could not get it any lower. bleed valve had no effect . in the end i took it off put the r33 one back on and used a bleed valve to get it to go to 10 pound runs sweet now
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
