Which date suits you best
14 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
haha yeah.. none of these common stagea things.. see them everywhere now. :rofl:
jerome - bit of a never ending saga with my car, but its coming from brisbane via adelaide, and was supposed to be on a truck last friday, but it never made it.. supposedly made it today.. but who knows!
  • Replies 71
Hmmm not exactly the present you were after ay Mitch..... oh well, have a good day anyway, Happy Birthday!
Your car will be common enough soon..... just give a year or so, they will just keep getting cheaper.... like all of the imports!
How many Companies complying these now? I could check.... too lazy (err I mean busy).
hello geezas !
I am just back from down south on a long weekend!
yeah dale I am sure we can arrange something .. and we are free both weekends but the 11th is better for us.
sweeeeeeet - seeing as though Mitchy and the traitor mobile have already bailed :)
I have never rolled naked on the bonnet of an S2 before so I am looking forward to it.
yes Sean i have updated the front page with the date...will put time and location in a few days :spank:
11th of November it is... :)
Hi KIrsty . Cory with black s2 11th sounds great the 28th october drag wars is on again ! will be running again . Runner up last time hoping to win this time out . Its good to show those evos & wrxs how a good wagon fairs ! And even a gtr .
Yes Brad will update that tomorrow..have added the time :(
Can we have a count on how many are joining us so i know how many maps to print and so that we hang around for everyone :)
1) Brett and Me
2) Shayne
3) Brad
4) Alan
5) Sean
6) Daniel
7) Graham???
8) Cory
9) Sean
Edited by Wildcat
Yes Brad will update that tomorrow..have added the time >_<
Can we have a count on how many are joining us so i know how many maps to print and so that we hang around for everyone ;)
1) Brett and Me
2) Shayne
3) Brad
4) Alan
5) Sean
6) Daniel
7) Graham???
8) Cory
9) Sean
Yes Brad will update that tomorrow..have added the time :thumbsup:
Can we have a count on how many are joining us so i know how many maps to print and so that we hang around for everyone :P
1) Brett and Me
2) Shayne
3) Brad
4) Alan
5) Sean
6) Daniel
7) Graham???
8) Cory
9) Sean
10) John & Iolanda
so whats the skinny on the final destination for the cruise? york somewhere yeah?
Well i have updated the front page 10am meet at city west for a 1030 leave....
will be nice to have a good turn out again :huh:
Edited by ssshonky
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
