In response to andrew opening 300 odd threads that the vic guys can't drive we though its time to put it all to rest.
We are coming up to NSW next month nov 7th to 10th to race at wakefield and eastern creek.
So as we can't drive we trust you will all be there to show us how its done..... :domokun:
We will be in goulburn/wakefiled from tuesday until friday staying at the wakefield cabins.
If you are going to come down for a race or catch up or anything let us know.
I'm not competing just going up for a week away off work and some fun.
Photos from last year;
http://paulr33.skylinesaustralia.com/photo...hts/page_01.htm
Our main event organising is here;
http://www.skylinesaustralia.com/forums/t1...0&start=120
https://www.sau.com.au/forums/topic/189223-vic-cant-drive/
  • Replies 139
haha i figured as much!!!
nah no wang burgers, screw the bbq
come down if its not too far from where you guys live
we will be out for dinner etc on one or two of the nights as theres nothing at the cabins
https://www.sau.com.au/forums/topic/189223-vic-cant-drive/#findComment-3410444
hahaha rofl
We do not concour with andrews comments!!! :domokun: hahaha
I'll try and get to EC if my car is sorted
Everyone knows Im the NSW DECA champ! :P but yes, would be good to catch up with you Vic guys up here and I'll try my best to get to one or both of the race meets :)
Cheers!
Chris
https://www.sau.com.au/forums/topic/189223-vic-cant-drive/#findComment-3410565
sunshine.
wait... who's team am i on?
Be on my Team!
Anna and I are planning to come down again this year cause we had so much fun last year....leave the megaphone at home and try not to steal other peoples meals off of the counter at the pub!
I am also bringing the crazy old man of SAU QLD Noel aka fineline
Should be good
https://www.sau.com.au/forums/topic/189223-vic-cant-drive/#findComment-3411401
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
