pretty sure they have to honour your lease even if they sell. once the lease is over they can boot you. or just make sure its a mess whenever you allow people to view the property, talk about the leaks etc etc
  • Replies 139
yeah.. chris, i wouldn't be too worried, they're probably buying an investment property! Ask the agent!!!
also draw cracks on the walls!
Anna,
Will let you know thursday also :rolleyes:
man,
just had the realestate agent over, they took photos n shit as its going on the market. farkin. we just signed a 6 month lease with view to 12, i was hoping to be here for 12!!
DAMMIT shit
oh, and place was a complete mess hahahahaha
Wow that was fast!
Buy the place :dry:
they are?
where?
hahaha yeah Im gonna mess the f**ker up, in the master bedroom I'll leave out some handcuffs, baby oil, a cat of nine tails and leave it there for the open house :yes:
lol steve - I have actually put an offer in, its 20k less than what they want...but we'll see :(
Anyone else from here going out on friday?
Oh noooooo :D
Thats so crap Bunts!!!
Was looking forward to catching up with you guys and finally get to see the car!!!
Oh well will just have to make a trip up to see you at some stage!! :D
yeah it blows, have had two offers on the car now so looks like you will never see it! All things going to plan the car will be in Cairns by early December!
I do Brad, tell ya what, I'll use your GTR!!!! :thumbsup:
deal? haha
Mav is up?? hahah sweet !
Anna, hopefully picking it up friday sometime, still not 100% - exhaust is restrictive, need a hiflow cat now! d'oh
Awww wow that was quick!!!
Can you at least send me pics of it so will get to see it that way..
I have work email now also will pm you :glare:
Are the vics going out after EC before they go back home??? A dinner or anything been organised......
Wont be making it to Wakie today..had to work after all :)
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
