recently i have been helping a mate install and tune a wolf 3d V4 onto a RB25DET NEO engine. it is a wire in ecu and as i worked through the wiring process it came to me that this ecu doesn't have the built in option of VVT control like th newer V500's.
now what i have been thinking about that may work is to use one of the wolfs auxiliary outputs programmed to switch the vvt solinoid at a set rpm, most probably through a relay. for the people in the know would this work?
or has anyone had any experience with the wolf V4 wire in on vvt engines? how did you do it?
also what rpm does the vvt switch? and whats the solinoids operating voltage? i'm guessing 12v.
Edited by QWK32
https://www.sau.com.au/forums/topic/189235-wolf3d-v4-and-vvt/
The V4 Plus R32/33 Plug-in does have the VVT control built in.
I believe your theory should work, but i am NOT a mechanic so you'll better wait for a more experienced opinion :P
You other option is to contact AEM and ask them directly, they are always willing to help :domokun:
I believe your theory should work, but i am NOT a mechanic so you'll better wait for a more experienced opinion :)
You other option is to contact AEM and ask them directly, they are always willing to help :(
yeah its the wire in so not vehical specific, and has no vvt function. and i'm sure its not the V4 plus, just the V4. basing this on the fact that it only has 4 ign outputs and 4 inj outputs. i have seen on the V4 plus it has the option for 6 ign outputs.
i'm fairly confident it'll work that way just need to know what rpm the vvt change over occurs at, i've read 1100 ish on and 5500 ish off, can anyone confirm this. and what voltage will activate the solinoid, 12v i believe?
Edited by QWK32
Tha's how mine works. Actually, it uses 2 changeover relays, that basically switch VVT off for idle, switch on at 1500, then switch off at 4500 (roughly).
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
