R33 Gts-t 440+ Rwhp
:domokun: Ok boys and girls regretful sale here, but it has to happen as it is time to let her go to a new home. The car is just not practical for our expanding family.
Ok so here it goes.
ENGINE WORK ALL PROFESSIONALLY DONE BY SUB-ZERO.
CAR IS PROFESSIONALLY TUNED BY MASTERSON MOTOR SPORTS
AREAS FORGED PISTONS
FORGED CUNNINGHAM RODS
METAL HEAD GASKET
DEAEK FORGED BOTTOM END BORED AND HONED
BALANCED AND BLUE PRINTED
N1 OIL PUMP
NI BEARING KIT
CUSTOM FMIC AND PIPING
CUSTOM SUBZERO PLENUM AND THROTTLE BODY
GT35R TURBO
1.06 HOUSING
MICROTECH LT-X 12
MSD DIS IGNITION PACK AND MSD SUPER LEADS.
TWIN PLATE EXEDY CLUTCH.
E-BOOST 3 STAGE BOOST CONTROLLER 5-14-19 PSI
BLITZ POWER METER
TIEN COILOVERS
3"EXHAUST AND CUSTOM DUMP PIPE
CUSTOM GTR FRONT BAR
GTR REAR WING
18"TEMPE DEEP DISH RIMS
18X9 REAR WITH 275 AVENIS SEMI SLICKS
18X7 FRONT WITH 245 DUNLOP SP 9000
HAS SHOCK PROOF GEAR BOX OIL
AND MOTUL 300V CHANGED AT 5000KM
THIS CAR HAS ONLY BEEN TAKEN DOWN THE STRIP ONCE SINCE I HAVE OWNED IT AND IT RAN A 13.2 AT 124MPH
IT IS CAPABLE OF RUNNING TENS WITH THE RIGHT TYRES AND SOFTER SETTING SUSPENSION.
It also comes with the following extras.
.82 TURBO HOUSING
HIGH MOUNT MANIFOLD
CUSTOM CARBON BONNET
3X12" BOSTON COMPETITOR SUBS
2X AVANTGARD AMPS
18" TYRES
THIS CAR IS CAPABLE OF 500RWHP+ WITH MORE BOOST AND UPGRADED CAMS.
$24500
IF INTERESTED SEND A PM.
THIS IS A VERY CLEAN AND WELL KEPT R33
Edited by subzeroR33
  • 2 months later...
  • 1 month later...
 Share
    • Thanks. I agree, looking at those plugs in conjunction with good compression/leak down tests I'm not too certain its ring related anymore.  I have a Swagelok ball valve on the drain and tubed it lower down to the left side of car to easily dump it into a container. I do not drain back into the sump. I've never had to drain it though as there's never been any oil in it.
    • Best bang for buck at the moment would be a 86/brz. Good chassis,  plenty of aftermarket support and parts everywhere.   I just picked one up with some quality gear and it drives better than my old 180sx.    Also depending on what your doing and budget.  An a90 supra is my pick if want to spend more. Great chassis, solid motor, gearbox is good. Development potential is crazy. They are doing well in prod sport and time attack. All the old jdm stuff needs alot of work as most of it all bent and over priced.
    • It's basically the same platform, hence why everything bolts to everything else Kelford camshafts were recommended by Mania after they asked me what I want the car for, I said "I'll thrash it around daily and maybe take it to the track for fun" 🤣 Factory NC 2.0L cam specs: - Adv. Dur. 256 /256 - Dur @ .050 205 /190 - Lift 9.42mm/8.13mm So, as I know nothing about cam specs, all I can say is the numbers are different and it should get a little bit of lope....🤣
    • Depends on how extreme, however if you look at SMSP, they're all dominated by Hondas and M cars on amateur/street car events.
    • Without better pictures, it won't be possible for anyone to work it out further than we have.   Start measuring, EVERYTHING. Thickness of flywheel, and all around it. You want to know is if everything parallel. If from the face of the pressure plate (that bolts to the flywheel) if it is parallel to the pressure plate face, then something is NOT parallel or equal elsewhere. Or you've bent the shit out of the fingers in the pressure plate.
