hey guys i have up for sale some r33 stockies with tyres that are still just roadworthy. the rims are in really good condition and i can send pics upon request.
I want $250 for these.
Also have some white sparco rims that are 17x8 and 17x9. they have 235 tyres on the front and rear. these are in good condition and same deal as the others, i will send pics upon request.
im after $900
Im located in Melb eastern suburbs.
can call 0433 179 630 or 9736 3696
Cheers
Nic
https://www.sau.com.au/forums/topic/189353-fs-r33-stockies-and-white-sparcos/
buddy just have a look on the inside of the wheel
u will see some numbers like 17x7JJ etc etc or 44j, 25j etc etc depending on the rim
just post the numbers up
fyi - in 17x7jj the first number is the diameter which will be 17 in this case then X second number will be width of the rim
the 44j means the rims have an offset of 44
saying its off an r33 doesnt really help much offset wise as many diffferent offsets can be fitted onto any car
cheers
Edited by purple5ive
fyi - the first number is the diameter which will be 17 in this case then X second number will be offset
cheers
no... first number is the diameter, second number is the width.
if they are the same as my 17x9, and 17x8 sparcos, they would be +38 rear, +32 front
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
