im wanting to install an amp and a sub into my r33, just wondering if theres a tut on running the wiring etc, i want to do it myself, but need some pointers on how to do it, i guess i run a cable form the preout off my new pioneer headunit around the drivers side dash(underneath), and around the door trim down the bottom?.....is it easy to remove everything???
need some guide please, i like doing things myself, even if it takes me 10 times longer than someone else whos done it!
also, wheres the easies place to mount a sub?
https://www.sau.com.au/forums/topic/189354-installing-amp/
soooo... you want a sub now? ;)
You need to run RCAs and switch wire from the headunit to the amp
You need to run power and ground from the battery to the amp
Then obviously wire from the amp to the sub
Run the RCAs and switch wire from the back of the headunit, down to the floor of the driverside door, keep the wire up high and hidden... Pull the plastic foot guard off the chassis near the carpet, through to the back seat which you will also have to take out, and then through to the boot... if that is where your amp is going...
To get the backseat out, there should be 2 10 or 12 mil bolts holding the bottom part in place, then 2 plastic clips in holes holding it really in place... Getting this seat out may be the hardest thing you ever do... it sucks...
Once that's done, you can see 2 bolts holding the back half of the seat in place, undo them, then slide it up... It should have just enough clearance to pop up and out...
THEN you will see a metal plate behind that and some fabric shit... piss that off too...
There's a lot to be done, it isn't really a small job, especially the first time you do it... what state (aus)are you in? Someone might be able to give you a hand :P
https://www.sau.com.au/forums/topic/189354-installing-amp/#findComment-3412412
hahaha, thanks mate, try Windy Wellington in New Zealand!!!. not in aus sorry dude. Umm, thanks for that, im pretty sure ill get the wiring sussed out fine, how much length will i need from headunit to amp(if im placing it in the back), and what gauge wire should i run, im going to do it bit by bit.And also......i want to place the sub in a place where its not in the way at all....is this possible in the 33's??, i was thinking next to the hicas ecu or something, so i can still get my spare tyre out etc no problems, and still have all the boot space!.
Also, what type of sub/amp combo would work well for cheap for some punchy bass(not big and boomy), im nt even into big car stereo, but mine just plain sux even after the new headunit, and speakers!!!
thanks
https://www.sau.com.au/forums/topic/189354-installing-amp/#findComment-3412714
you will need about 5 metres of RCA and switch wire... you can get them together normally... the switch wire is just a wire...
You will only need about a metre of 8 gauge power cable (1m positive, 1m negative) for the amp if it is going in the boot...
Im thinking either a 10 or 12 inch would best suit your needs... you can put it next to the battery, but i would assume that its not all that easy... The box would have to be custom most likely... there are a few threads on it on the forums though, do a search...
Dunno about cheap subs/amps believe it or not, so i can't really help you there :rofl:
https://www.sau.com.au/forums/topic/189354-installing-amp/#findComment-3413634
if you wanna spend a bit extra get a sub box that is moulded to the corner of the boot. most places have prefabbed ones gonna cost me $350 for one for a 12" sub to go into my r34.
And importantly dont forget to put a fuse between the battery and the amp (closer to the battery is better) and if your battery is in the boot then its even easier. and depending on the amp you get for the sub will depend on the gauge of wiring need. 8gauge is pretty normal but higher end amps can take 4gauge and if they can take it you may aswell run it.
have fun :) I always do that stuff myself. It takes me heaps longer but its way more satisfying knowing you did it that just paying someone to do it.
https://www.sau.com.au/forums/topic/189354-installing-amp/#findComment-3413794
Grab a wiring kit from Autobarn, 2 channel or 4 depending on how many channels your amp has. Kit will set you back about $50 and incl all the wiring, and cable ties and stuff.
Run the RCA cables through the passenger side, that's what I usually do, as your more than likely to run the power cable (thick red cable) down the drivers side as the battery is located on the right of the engine bay.
This way there will not be any interference in the sound.
Ground it off the boot lock latch, makes it easier because you can run the wiring under the carpet.
Hope that helps.
Thanks,
Abu
Edited by abu
https://www.sau.com.au/forums/topic/189354-installing-amp/#findComment-3413931
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
