R32 Gtr Half Boost
hazerb30
 Share
Hey Guys,
My GTR wasnt pulling anywhere near as hard as usual last night. I watched the boost guage and its only hitting 0.3 bar and sometimes might make it to 0.4
So im fault finding and could use some help.
Its a pretty much stock R32 GTR 140'000kms.
Standard computer
I believe the turbos are the standard ceramic ones still.
Aftermarket exhaust
I believe the boost restrictor may have been removed but to be honest ive never checked. I think it goes to near on 1bar so i think its been taken out.
Engine sounds normal, no change or nasty noises. Drives fine im just keeping it off boost now until i get it figured out.
I didnt hear any pop or bang noise or any 'moment' when it went wrong.
No bad exhaust smoke
I had a compression tester available a couple weeks ago so i did that for interest sakes. 160 to 164 accross all which i believe is good.
From reading posts on here a lot of people said their gtr's stopped making full boost because the computer detected knocking or leaning out. They would turn ignition off and back on and then it would make full boost for a while. I tried this and mine never makes over .04bar.
Where do i go from here ?
Edited by hazerb30
advice anyone?>
My friend thinks it might be the wastegate stuck open on one of the turbos. Im going to pull the intake piping crap out of the way and have a decent look in there.
Something simular happened to me.
Things to check,
  • CAT to see if is blocked
  • Wastegates to see if there are stuck
  • While checking out your cat look for tiny bits of exhuats wheel
  • Check all pipping to and from the turbos
  • Check all intake pipping as well
That pretty much covered it. If you fined you have a blown turbo i have a spare one here. I pray for you it isn't a turbo.
To check for leaks just get some "start you bastered" and spay it all over the pipes and listen to the engine if it rises you have found your leak!
Good luck with it all.
Cheers. Ive just got back from pulling it to bits. I didnt get as far as pulling the turbos off cos daam that looks like an all nighter and i didnt have any bandaids
I did get the pipework off them though. What i found:
On the rear turbo inlet pipe there is oil coating the sides and a dribble of oil pooled in the compressor side. The front turbo pipes are clean. What it looks like to me is the oil is coming from the breather hose thats attached to the rocker cover. Its all i can think of that would explain how oil gets in before the turbo. Is this a normal thing to get a bit of oil blowing in and surely this much would be excessive?
Now from what ive read here the worst case scenario would be that bits of the ceramic wheel have gone through the engine and scored the pistons and bores and that would cause this oil covering the pipe. Unfortunately there was no cat in the car to catch any fragments so i cant check there (my friend borrowed it to get his starion over the pits :D ). To me it seems like i would have to pull the turbos off to see whats happening
I dont know for sure what the turbos are. All I could see was garret 1-2 written on them. If they are the ceramic turbos i dont see any point pulling them off without having replacements ready to go so ill have to research what to get. Anyone in WA that has something lemme know !
There was no 'moment' when this happened. No bang, nothing. just started it up one day and noticed it wasnt pulling very hard. I know the car pretty well so you'd think id notice when something went wrong.
So im thinking of this plan so far:
Compression test to see whats what
Locate replacement turbos
Pull old turbos off and see whats what
Pray for the best
What do you guys think ?
Pulled off all pipes to the turbos, checked and reattached
Wastegates are not stuck
compressor blades are still there, cant see exhaust
Reset ECU
ECU Diagnostics are 55 meaning all ok
Ive done a compression test ~160 accross all
Car idles and drives fine, Still only making 0.4 bar
I havnt pulled the turbos off yet. Surely if the turbo went while i was driving it i would get smoke or at least hear the wheel shoot out the exhaust. Is there some other way to know the exhaust wheel is gone besides pulling the turbos off?
Not getting much help here? Im stuck driving an 80's hilux ute with a speedo cable that drags on the road ! i guess i should be appreciative of that..
could it be something to do with the BOV's? how could i check
Edited by hazerb30
Reset ECU
To check the blow off values just put a metal sheet where the blow off values connects to the pipe. So basicly blocking off the blow off value. Did you check the exhaust wheel? Did you spin the turbo wheel and did it spin nicely?
When i lost a exhaust wheel i didnt' here anything but i lost ALL boost. So my problem is slightly different.
Just one more time though, have you checked all the pipes?
I had alot of oil in the rear turbo but i think it's because i don't a have a catch can.
I didnt spin the turbo :laugh: I had to use a mirror to look in the pipe to see the compressor wheel
Ive got a catch can on order so i can see just how much is coming out the breather. Glad i pulled pipes off to see what actually happens now and understand the usefulness of a catch can
Whats the easiest way to get to the blow off valves ? Pull the front bumper off or something?
Thanks for the help!
Michael
Edited by hazerb30
I didnt spin the turbo :w00t: I had to use a mirror to look in the pipe to see the compressor wheel
Michael
Just take the front bar off. Easy as 10min job.
I was a bit silly going all that way to the turbos not to spin them! :laugh:
i pulled the front bar off. For anyone reading this in future and looking for help. It took a while because i had the find all the screws and some were siezed.
http://www.skylinesdownunder.com/index.php...4&Itemid=44
So now Intercooler and hoses are off. pulled the outside covering off each intercooler hose and couldnt see any splits or leaks. Intercooler looks clean but im going to flush it with 50/50 methylated spirits and kerosene. Ill also take it to a radiator place tomorrow to make sure it doesnt leak.
Buying new intercooler hoses even though these look ok. When i put new hoses on should i bother putting the original rubber outer covers on? see pic
These are the ones im planning to buy . wish they made them in black.
http://cgi.ebay.com.au/INTERCOOLER-HOSES-N...1QQcmdZViewItem
Will check BOV's once i get the intercooler back in. Unless there are checks that can be done without the car running. Theres a pic there of the left one
Edited by hazerb30
Good Luck with it all. When I replaced most of my hoses i gained about 2-3psi. Made boost quicker and pulled harder.
Don't forget to come back and finish the post for future readers!
Thanks man. Ill keep posting as i find things ;)
Having fun pulling stuff apart and seeing how it all works atm. I only get a couple hours a day to really do anything.
Last night i took the intercooler out and flushed it with kero/meth spirits. it does a great job! So ive got all that back in now with new hose clamps everywhere and ill start the engine again tonight and see whats what.
With the BOV valve test, do you mean that i should loosen the bolts and slide a flat bit of metal in there to completely block off their exit and tighten the bolts back up?
Its back together again minus the front bar. Still runs great just no change to the boost level. I went looking for leaks in the piping / intake manifold with a can of Aerostart. Couldnt hear any change in the engine rpm.
I read that when one turbo goes it means one of the inlets sucks and the other blows. Both inlets to the turbos are definently sucking air in.
Didnt try out blocking off the BOV's, wasnt confident of doing so.
I think im gonna give up and take it to someone who knows GTR's and see what they reckon.
Nice! Off to bunnings tomorrow. So its a case of blocking off both afm's and the exhaust and pumping in air from a compressor starting at 10psi through to no more than 20 psi and look for leaks.
Ill keep yas posted
Cheers!
Mike
Ill keep yas posted
Cheers!
Mike
Yep and just spray water around the pipes so you can actuly here it.
ok another collection of stuff that happened last night
Air leaks were almost non existent. Small one around the BOV which tightening the bolts corrected. That was a bit dissapointing as i was hoping to find something.
So we also did this stuff
Checked fuel pressure, went for a drive with fuel pressure guage duct taped to the windscreen. 55psi under load at WOT. It never dropped off with rpm or load.
Used another boost guage for reference and got around 7 psi which means my other guage is correct. (For reference the stock boost level on a r32 gtr should be 0.8 bar /11psi)
Used a air pump with a pressure guage on it and put it on the actuators for the wastegates. Both of the wastegates just start to crack open at at ~0.6bar. this seems too low?
We wired the wastegates shut and went for a drive (now with 2 guages duct taped to the windscreen! ). Still refused to make over .05bar boost
Checked the timing. 20degrees BTDC which is correct
didn't read the entire thread but have you tried to drop the exhaust before the cat and test drive?
basically if you remove the cat (bolts on the dump side and bolts on the cat back side) so you have a gap where the cat was, go for a drive (yes it will probably be loud and illegal).
since there are no leaks, no broken turbo's, the only other thing it can be is the exit..
a collapsed cat will cause a massive restriction.
the above test essentially removes the cat.
if it all boosts up perfect like it should, bolt the cat to the dump pipe but not to the rest of the system.
another drive.. and see what the boost does.
back down to 7psi? - Cat busted.
still up at 14psi (or whatever you have it set to) - pipes/mufflers from the cat back busted.
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
