Hi guys well im thinking of selling my 1997 model series 2 s14 200sx SELLING UNREG...
Mods: Stage 3 crower cams,Power fc,555cc injectors,Fmic,3.5" exaust,Tein Coilovers,Sway bars,Strut braces...
Interior: Standard interior just pillar gauges...
Body an Paint: (TOP) Black with silver glitter (MIDDLE) Red marble hard 2 see in pics (BOTTOM) Mercedes silver. Carbon bonnet an boot custom ADR STICKER rear guards wide boy front guards and mirrors an tail lights...
Stereo: JBL 12'' sub, JBL amp for sub an sony amp for splits, Pioneer headunit...
Wheels: Kustom painted black Koya's Rear 11" Wide tyres Ventus 285/30zr20 99y Front 10" wide tyresFalken 235/30zr20 88y...
Also got best inovation trophy at this years powercruise...
Got told that paint and body work was around 16g and got told rear guards took 190 hours of labour to get them the way they are dont have reciept for the body work or paint. It also has had a rebuild which cost $$$ have reciept for it and the car has 133000kms about 10000 on engine very well looked after and rarely driven also no stupid offers please as i will keep it if i cant get what im asking for it.
Thanks for looking Shane...
RWC supplied: No
Currently registered: No
Item Condition: Very good
Reason for Selling: Looking at buying land
Price and Payment Conditions: $23000 or swap for cheaper car of interest and cash my way
Contact Details: Email: [email protected] or Ph:0401 966 921
Milage: Car 133000kms Engine 10000klms
Edited by ryder111
  • 4 weeks later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
