Hi, I have an R32 GTR, when I take off the front torque split goes to max on the guage. I recently fitted a TSC (torque split controller and thought it might have been faulty but I removed it today and it still does the same thing? As soon as the car rolls, either forward or backward it all binds up, the rear diff locks, as if it were a locker diff and the car fights itself to move. When I was reversing on a slight incline today I noticed that the car wouldnt roll dawn the incline when it was running but when I turned the car off you caould feel everything release and the car started rolling down the incline. Start the car and it would all bind up again. Tyres are all the same. I read a post where someone checked for error codes on the ATTESSA computer, can someone also tell me where the computer is and how to check for the error codes. At the moment the TSC has a 2WD switch, and when I leave it in 2wd it is fine, so I am driving around in 2wd mode, I am thinking that this could also mean the the G force sensor in the car is stuffed as this is what the TSC is wired into but this could also be masking another problem somewhere else in the drive train. I have done everthing I can think of to resolve the problem but to no avail. I swapped the front and rear tyres around as I recently fitted new tyres to the front (same brand and size) but was told that the different wear may have caused the problem, I now know this was not the problem. Has anyone had this problem and can shed some light on this for me?????? HELP!!!
Edited by IDO 11S R32
https://www.sau.com.au/forums/topic/189374-attessa-4wd-problems/
Dont know, will post a pic, it has coilovers, this is the next thing I will sort out, I noticed today that the drivers side rear is lower then the passenger side rear by about 10-15mm. Dont know if this would effect it, front isnt that low though. I have had the car for about two months and it has only just started doing this I haven't touched the suspension since purchasing it.
NO, but did check the fluid level, it is slightly overfull. I recently changed diff and gearbox oils, first I thought I had blown the diff, or it was on the way out at least, but it makes no noise, very little diff slap and works perfectly when in 2wd mode.????
attessa computer is the silver box on the underside of the parcel shelf, at least on my 4dr gts4. As far as I know it will only flash ecu error codes when the 4wd light is on, signifying an error. Theres a red led on the underside of it.
If the center clutch pack is stuffed, how do I fix this? What sort of money am I looking at, and where should I take it to get it fixed? I live in Western Sydney near WSID. How sure can you be that its the clutch packs?
Did you check the TPS connection when you asked before about this problem????????
Yes I checked the connections, they are all fine. I even disconnected the unit from the car but it still had the same problem? Took the car to CRD today they dont know what is wrong with it, it is now booked in for next tuesday so they can go over the car and see if they can find the problem. Will let everyone know what it was when we have it sorted.
Blind elk, you are a legend!!!!. I have found the problem to my 4wd nightmare. It was the throtle position sensor. This is how it all went wrong. Now my car has had a single throtle body conversion done, why I dont know, but it has been done. On the single throtle body there is no TPS, so when blind elk said to check the TPS I counldnt as there was none. What I forgot that just prior to this problem occurring and in fact the day I installed the TSC I decided to clean up the engine bay. The standard throtle body linkage was still in place with the TPS connected, I dosconnected it and drove the car, it went fine, so I removed the whole linkages. Then the problems started. I didnt even think about this, until today I was in my garage thinking about what the hell could be wrong with it, when I saw the linkage sitting on my bench with the TPS attached and thought, hang on!!!!!! I connected it up and whala, it all works perfect. I reinstalled the linkages and connected the TPS and it all works fine now! And so ends my weeks of hell, however no a massive exhaust leak from the manifolds has emerged, will this ever end!! At least I have planned on changing the turbos to N1 2860R-5, I have ordered them but am still waiting for them to arrive. I will check other forums but there is one on installing turbos right? and can it be done at home or will I need a hoist?
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
