hey guys,
im looking at building an s13 silvia drift car....im thinking rb25det, 180sx front & r32 rear end.
now im not concerned about the 180 front or rb25....only about the r32 rear end...here are my questions.
1) can it be done?
2) if it can be done, how difficult is it & what needs to be done?
if you have attempted this or know someone who has plz get in contact with me.
would of posted on ns.com, but thought i'd try here first.....aslo tried search but nothing came up.
cheers
Andrew ;)
https://www.sau.com.au/forums/topic/189382-custom-s13-rear-end-possible/
Never heard of anyone attempting to put a 32 end on a s13/silvia before. If you've got the money, anything can be done. Wouldn't have a clue how easy/hard it would be, but I've never seen it done so I'm going to say it'll cost quite a lot, or it's a hard job.
I've seen R32 rear lights crammed into a 180sx, complete custom fabrication which shouldn't be too hard if you're handy and have nothing better to do.
There's also been at least 1 fairly good attempt chucking an R32 front end on an S13 chassis which worked alright, so that can be done.
As for the rear, theres nothing off the shelf which I can think of to make this easy, about the only thing that 'may' work is an R32 widebody kit with a fairly humongous amount of fiddling put into the anchor points where it bolts on. Bumper would be much the same case, modified bit of aftermarket kit.
I sort of shudder to think of the amount of bog and glass it'll require to hide the gaps... then, being a drift car, it's gunna get f**ken smashed into something sideways and yep, well, kinda rich to fix. >_<
Are you sure it wasn't a r32 with a silvia front that you saw? that would be alot easier.
well if it wasn't a silvia, im from pluto :rofl: nar, i compared an r32 & an s13 on my comp to verify it was an s13....guess i was hoping i could do it, but luck doesn't seem to be on my side ;)
engine swap + rear end... like everyoen said just get an R32 and slap the s13 front on it..... i dont think that would look good because the s13 front is narrower .... i just cant see it as a good mix.
not going for looks, as it will be a drift car....so yer dunno yet **edit: just realised why am i going for 32 rear end if not for looks? well guess i want it to be unique**
It would be far easier and cheaper to stick a 180 front on an R32. Plus the engine swap would be a bit less hassle too.
Ryan "Jilted" from SilviaWa made one here in perth about two years ago. First one in Australia we believe.
Pic1 :sorcerer:
Pic2 :sorcerer:
It is easier to put R32 lights into a 180sx as the shapes are the same and it requires extensive modification to the low garnish under the lighs ie a custom made one of garnish.
But it has been done...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
