guys just quickly, iv got an R33 S1 GTST, now the stock thermal fan at the front, wen does it kick in or does it. Iv heard it supposed to kick in wen the A/C is turned on, but it is NOT activated by temperature levels. Mine doesn't activate wen i turn the a/c on at all, does this mean its not working???
let me know ur thoughts
cheers
https://www.sau.com.au/forums/topic/189390-r33-thermo-fan-kick-in/
it will only switch on when your a/c is on and you go ever a certain engine temp. the temp probe is the one screwed into the bottom of your radiator. you could check to see if the probe is plugged in. alternatively if you have or know anyone that has a consult cable and software you can do an active test where you switch it on through that.
yeah i believe it will come on with aircon when required.
on a side note, what happens when you put a fmic in front of that temp probe?
does it see temps as hotter and therefore turn on more readily? any adverse affects?
nah that a different probe. the one your taking about is the outside air temp. there is one screwed into the bottom of the radiator, so that when the coolant/engine temp gets to hot it switches on. the only time i've ever heard the fan come on was in the middle of summer and in really heavy city traffic.
so that thermo fan actually kicks in to control engine temps???
i thought it was purely for the aircon
thanks fellas.
to comment i would've assumed it should kick in at high engine temps like other cars.
but like mentioned above i was told purely for aircon. so even if the aircon is on it wont kick in until a certain temp??
these cars must hav good cooling...!!
  • 2 months later...
yeah..thatur a/c fan..
does ur clutch fa come on??
if not...,thats wat i'll be worried about...
but for ur question lik a few people mention it should come o wen u press ur air-con...dependin on how hot it is aswel..if its required..
another question not related...
how people hear have done a clutch fan conversion to a thermo fan on a r33 skyline??
I will be converting to a 16" thermo fan as part of my RB30DET conversion. Fan will be spaced approx 30-40mm off the radiator and use the stock shroud. Fan opperation will be speed controlled using a picaxe micro controller and stand-alone temperature probe.
The whole process has been halted at the moment due to the x-mas break though...
you'd be better off using AU falcon thermo's and shroud and simply attach to your radiator and seal the edges.
    • Standard GTRs are boring and there plenty of them, do what ever you want to it and just remember nothing about them is cheap anymore and if you’re picky about how you want things done it gets even worse.    if it’s an n1 or something very limited then maybe care more about it’s heritage
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
