I was incredibly saddened to hear of Anders Oloffson's passing. At such a young age too.
Jetwreck, thanks for the amazing pictures! I don't suppose you have any of the start of the Great Race from 1990, 1991 and 1992 do you?
Also, I am looking for good clear pictures of the interior of the Gibson R32 GT-Rs from when they raced (1990, 1991 and 1992) - and also of Channel 7's Racecam camera. I'd like to see how it was mounted, where precisely it was mounted, the size of the camera, where any cabling went to etc. It's an odd question I know, but this is one detail of the cars that no-one ever mentions and that I don't have any pictures of (unless I took a screen grab from the race coverage...)
They got mounted on the cross bracing just behind the driver. Reason you don't see them much is that channel 7 removed them after the cars finished racing for obvious reasons. They were fairly large/heavy.
If you get some footage of the 92 race you will see Jim Richards giving the thing a funny look when the extinguisher foam that filled the interior of the car (went off for no good reason) came off the lense of the camera & flew past him.
  • Replies 169
Posted Images
Sorry mate,
The closest pic I have of the any of the starts is the one with the R31 in it. I have good inside images of #1 Winfield car...but the were all taken just after Terry Ashwood had done it up.
I have looked through my pictures and I have none with cameras in the cars. Like the ones in our cars, they were most likely put in on the Friday night and removed on Sunday straight after the race, so not much opportunity to take pictures with them in place.
Cheers
Gary
Gary, Jet and djr81
Thanks for the replies guys. I appreciate it.
I think I may have to study the paused images from the 1992 highlights DVD to get a feel for the camera. I assumed it was quite large and heavy (it was 1992....) but I thought if anyone anywhere would have pics, someone here would! My next stop will probably be Channel 7's motorsport department. I'd say any request I put to them may be filed in the cylindrical filing cabinet on the floor.....
Jet - I'd love to see any pics you have of the Winfield before or after Terry's restoration. I have seen the pics from Zoom magazine, but if you have any others.... :(
Thanks everyone for the discussion and the pictures. It's great!
Cheers
Andrew
VID! DECA 2006 Skyline Nationals.
Hi B.J,
Thanks for the Vid....now I have proof he did DECA....Dad told me he had never been there before....lol. His that old he probably forgot...rofl!!!
Edited by Jetwreck
Alright I'll bite... why is there an AFM screwed to the left-hand strut tower?
To actually answer your questions, you would have to ask the person who put it on the left-hand strut tower.......my reasoning is as follows:
  • Looks Pretty
  • Balances the look of the engine bay i.e. Fung Sui
  • Only place it would fit
  • Give the car a balanced weight distribution
it's there as group A rules stated that a car equiped with an air flow meter as factory had to have one connected to the inlet tract to race in group A. since the engine management they used ran MAP sensors they got a stock AFM, bolted it to the engine bay, then plumbed it in with a small piece of vacuum hose. so it met the rules. a nice example of how race teams will bend the rules as much as possible.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
