Gibson Gt-r
Anyone have pics of the GMS R32 with the front wheels off so I can see the front suspension setup. If its anything like the rear setup it not exactly std nissan.
Cheers
  • Replies 169
Posted Images
Cheers
cannot find any in my collection.....may be earlier on in this thread..... if you wait a couple of weeks(19th-20th sept) it should be up at Lakeside racing.
  • 3 months later...
From memory 1984 (Rovers) was churns and 1985 (Jags) was an overhead rig, no maybe we didn't use overhead rigs until the BMW's. Too many Bathursts ago, 1,000's and 12 Hour races to remember, maybe time I got the video out again myself. When they were used, the churns were filled from 44's, which were on scales to record their usage. My pit job was crunching numbers, TWR had their own technicians, no Aussies got to touch the cars much at all.
is there much demand for the 84 rover as per pic as shown in post no.86?
my uncle passed in jan this year & handed this car to me just before, biege with only 75000km, 3.5ltr v8 with 5speed, forged bottom end, touring car style wheels as per pic - it was his pride joy :P
One of these went on ebay about 4 years ago for an astounding AUD$104! For a sticker!
I picked one up for under AUD$10, also from evilbay. You don't see these around very often now.
i'd like 1 of these stickers for my big toolbox, maybe even the back window of my gtr...where is it best to get 1, ebay?
Mine was free, and will never be sold. Lived a few doors down from a mechanic who used to work on the GMS cars, whom now works for Apprenticeships Victoria. His name has slipped my mind at this moment.
I guess after seeing a stream of modded 31's, a 1600 and stagea out the front he thought I would appreciate it!
I got mine off evilbay but they come up so infrequently - in fact I've only ever seen two there - the one that went for over AUD$100 (it actually went for $102 now I've checked!!!) and mine.
Attached is a resized scan. Mine doesn't appear to have the Nissan logo on the left either.
Edited by ajrichar
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
