After I bought my R32 I noticed the upper control-arm bushes squeak on bumps. On the hoist I noticed that the bushes were new nolathane ones. I pulled them apart to regrease them and noticed that they were a very tight fit and had already been deformed by twisting. I fitted grease nipples and refitted them but after couple of days they started to squeak again.
I think the bushes are too tight as I had to flog them out with a hammer and punch and the inner sleeve might be a bit short and causing the bush flanges to bind. The flanges on the front bushes look squashed but the rear ones look OK.
Has anyone had the same sort of problem and if so, how did you fix it?
https://www.sau.com.au/forums/topic/18946-squeaky-bushes/
are these urethane/nolathane bushes any good over standartd ones as in is this squeekin issue common with these aftermarket bushes?? my front left is leakin on my 33 and i was thinkin about replacing them with ones from unique auto for $85 a pair. anyone know where i can get these cheaper or better ones in melb??
cheers
https://www.sau.com.au/forums/topic/18946-squeaky-bushes/#findComment-418002
Guest schulziesr32
i have the exact same problem. They were put in by aparent suspension professionals, they started making that fantasic noise as soon as i drove out of their driveway!!!!! so i took it back. they replaced one of the bushes..... guess what it squeeked again. so third time lucky they tried to tell me the original manufacturing material had been changed so i decided to get them changed again under warranty.... the bloody thing still squeeks. i would save time and money and buy the original items from nissan and not so called suspension gurus!
https://www.sau.com.au/forums/topic/18946-squeaky-bushes/#findComment-431776
schulzie Were the bushes they fitted Nolathane brand (orange colour)? I wouldn't necessarily blame the guys that fitted them.
Nolathane haven't been making bushes for the Skylines for very long and might still be refining the specifications. I'm going to try to get the story from them.
https://www.sau.com.au/forums/topic/18946-squeaky-bushes/#findComment-432465
I rang Nolathane technical support this afternoon and found out that even though the bushes in my car are the same colour as theirs they are made by someone else. The technical support guy was very helpful though and told me that Nolathane make two types of control arm bushes for the Skylines. The original ones they made are a direct replacement for the factory bushes and the new ones (Part No.4544A IIRC) are adjustable for camber and castor and have only been available for a couple of months.
He reckons if they are greased in the right places they shouldn't squeak.
https://www.sau.com.au/forums/topic/18946-squeaky-bushes/#findComment-432731
Guest schulziesr32
they are a sort of red color... they were fitted by fulcrum.....i dont know if they used their own brand or not, but apparently they are adjustable..... they would want to be as i paid nearly $800 for both them and radius rod bushes. It really only seems to squeek when their cold and at slow speed. Its just embarassing some times caus it sounds like an old shitbox XD falcon!
https://www.sau.com.au/forums/topic/18946-squeaky-bushes/#findComment-433518
I'll get prices for the Nolathane adjustable ones tomorrow. I think I can get them through Repco and I'd expect them to be about $200. I'll fit them myself but it shouldn't take more than an hour or two plus a wheel alignment so I expect it would cost less than $400 all up if I paid to have it done.
https://www.sau.com.au/forums/topic/18946-squeaky-bushes/#findComment-434747
  • 21 years later...
I recently lubed up a dry poly bush that I have, and it squeaked maybe 10km (not 10,000km) after install.
I imagine this isn't supposed to happen with poly bushes or any. Piece of shit stuff lol. Used silicon grease from supercheap auto and I definitely put enough in because as I pressed in the bushing, thr grease came out.
Anyone else have this issue? I'm considering changing to rubber
https://www.sau.com.au/forums/topic/18946-squeaky-bushes/#findComment-7995793
40 minutes ago, GTSBoy said:
Which bush, where, and how frayed was the surface that you put grease back onto?
J arm bushing. Surface itself seemed fine. Are you referring to the metal roller or the j arm inner surface? If so, i degreased that inner surface it seemed fine.
Edited by silviaz
https://www.sau.com.au/forums/topic/18946-squeaky-bushes/#findComment-7995797
21 minutes ago, GTSBoy said:
This is an R34, yeah?
I'd either just buy new bushes, or do what I have done (on R32) and go sphericals. I am having Stockholm Syndrome with my spherical bushes.
Yep r34. The bushings don't look all that old. I was going to get the nismo ones but a suspension specialist told me my car would veer left, and I'd need to put in adjustable camber arms to stop it + wheel alignment because the nismo ones are centered. He recommended that I keep my existing ones because they are camber adjusted. What are your thoughts?
https://www.sau.com.au/forums/topic/18946-squeaky-bushes/#findComment-7995799
This doesn't make sense unless your car is a bit bent in some way and requires adjustable arms to provide even camber left to right. What arms are on it?
https://www.sau.com.au/forums/topic/18946-squeaky-bushes/#findComment-7995806
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
