Today i turned my air con on, and it was working normal for a minute.. the air was cold everything was sweet but then the fan just stopped and the display says its on flat out.
Why would it stop like that? could it be a fuse ? the motor is burnt out ?? what could be up with it ? anyone have any ideas?
I noticed that cold air was still commin out of the vents from the air being pushed from the outside the fan is just not working the air con is....
No solution, but I have the exact same problem, it started on the weekend.
I am tracking down a replacement fan to determine if it is infact the fan. It is most likely the fan as it had a bearing noise for a couple of weeks before it failed.
id say either you have popped a fuse, the plug on the motor has some shit in it or it dead. pull out the glovebox and you will find the plug going in the motor pull it off check for corrosion etc.
failing that just kick or punch it sometimes that works haha
we had a spare r32 fan there, pulled my fan out and put direct power to it and it worked. so the fan works properly. One of the wires on the plug that goes to the FAN has power it may not be dropping earth for the different power steps?
So im thinkin it could be the controll unit now? cos the fan works!
