ever since last winter my clutch has been squeeking but on and off not all the time. i got under the box and had someone press the pedal and it is coming from just inside the slave cylinder. is there anything in there i can lube up?
is it easy to pull appart? i have been told berfore that i might have to wait till the box comes out to fix it. i dont know if i can wait that long it is co farking anoying i feel like a dickhead at the lights
Cheers Ryan
https://www.sau.com.au/forums/topic/189517-squeeky-clutch/
My clutch squeaked a lot. My sounds were coming from inside the actual clutch housing. When a mechanic pulled aside the rubber boot which keeps it shut, sprayed some WD40 in and then we pumped the clutch - no more sounds. They said "the bearings have dried out" or something to that effect, and they said they could go in and lube it up etc, but they said they don't bother and usually just replace the whole clutch at the time (for a 10yo car).
https://www.sau.com.au/forums/topic/189517-squeeky-clutch/#findComment-3415934
Mine does it too.. so do many other R33's. Some people have had success with putting grease up inside where the slave cylinder line goes into, into the rubber housing.. (Ironically enough a person with the username "Mad082" posted a DUI for this lol). I tried this but it still squeeks. It's usually the throw out bearing apparently. I'll be replacing my clutch with an exedy HD in about a month or so, will just get it sorted then.
Edited by Simmo1985
https://www.sau.com.au/forums/topic/189517-squeeky-clutch/#findComment-3416487
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
