Yeah it has done quiet well. Especially the engines. some DA drivers are now using the LS1 and 2.
Although maybe one of the many reasons they are is because it will appeal to the Australian audience more
I guess what sometimes puts people off is not necessarily the car, but the hype that surrounds it. The Holden bandwagon, if you get what I mean.
Same goes for some people's opinion of Skylines.
Rotaries.
4 cylinders.
Etc.
One of the main reasons they remove RB's, 2JZ's etc is because LS1's are a lot lighter. Alloy block compared to a iron block.
Like the DLS R34 drift car, took out the RB25 Neo, chucked in the LS1, saved 50kg!!! Slapped some twin turbo's on it and you got a hell of a power to weight ratio over the stock engine setup.
lol right never seen one perform better in anything other than commo
Japanese cars with original Japanese motor always out perform the Japanese cars with ls1's etc fitted
kudas S13 with ls1 gets close but Im still not sold on it
Edited by 1400r
are you kidding have you seen it ?
power and torque do not make a drift car
speed,balance and driver skill do
ever seen a d1 ae86?
heres a link to a vid with D1 r34 with rb26 t04z watch it and try tell me that the GT Autosound car has the same balance at the moment
Edited by 1400r
what do you mean by 'balance' exactly? if you mean overall performance, the GT autosound car might need a few tweaks, but they are things that can be ironed out. an RB26 with a to4z would be nice but i cant see it being comparable to a TT LS1. more power, more toque, probly a more 'driveable' car on the track if that makes sense. not to mention the bonus of reliabilty.... :P
Edited by VB-
Once they ironed out the problems I'll compare again
until then LS1 being a better engine than those factory fitted is unproven regardless of extra power, reliability etc if it doesnt drift well what does it
matter if it makes more power than a rb or is more reliable
(Im including all rb's as basically being the same balance split wise front to rear although a 26 would weigh more than a 25 if it still had the standard twins)
by balance I mean the whole car working in unison not just a car that makes big power so must be sick yo
in a well balanced drift car the drivers can through the car in much harder and get back on the power much sooner than those with poor balance
skylines are well know for mid drift midcorner understeer Im yet to see how a Ls1 which "weighs less" than a rb has helped at all with this
you still see alittle in the Kakimoto 34 above and its been competing for awhile so all the bugs should be ironed out of it
from all that Ive seen of the Gt Autosound car(and Ive seen a fair bit) it's a corner exit smoke machine
1400R hits the nail on the head! The GT autosound car isnt a good set up atm as the driver doesnt have anywhere NEAR the skill required to use all of the power to its full potential.. all ive seen from that thing is straight line smoke ups and corner exits.. its lame. Then theres the reliability issues!! Its had a few issues thats for sure.
my RB has had none :P
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
    • After an excellent condition, working! oem radio for a 97 r33 And the steering wheel shroud/cover as mines a little bit scratched up Am in Melbourne
    • So my exhaust is loud and sounds awesome (good thing) but also is very loud when coming and going, dont want to piss off the neighours etc Are the varex adjustable mufflers any good? I contacted them but they dont make r33 specific exhausts Ive also see the adjustable inlets on this site but apparently they might restrict airflow too much which wouldnt be good for the engine. Would prefer something thats adjustable from in cabin so i can change it on the fly, dont really want to put in one of those permanent exhaust tip things.  Any other recommendations would be appreciated!
    • You don't need to lean as far to pour the oil in, or change the spark plugs either 😛
    • Indeed, it is much easier to get at the filter with the engine on a stand
