Hey ppl, selling my cefiro!!
88 model, factory 5 speed turbo
Pearl white, uras front bar, paint and body in good nick, apart from a small chip/dent on the drivers front guard, Interior in good condition, apart from the usual lifting dash
R33 GTST front seats
Momo steering wheel, with extension boss
Nismo gear knob
Oil pressure and water temp guages where the climate control usually sits ( climate been moved to below stereo)
power windows, mirrors, all work, full interior, air con has been removed (but still have all the parts)
Power mods
RB20DET
KKR 430 turbo, gtr injectors, front mount cooler, full 3 inch exhaust, walbro in tank pump, microtech lt12s, with external ignitor unit, running bosch coils, top gun 10mm leads, no airflow meter.
Makes 200rwkw (that was with old, half collapsed muffler)
Drivetrain
Exteme heavy duty clutch
gearbox in good nick, no noises, or crunches
Nismo 2 way diff
Suspension
G4 drift spec coil overs
Adjustable castor rods
Adjustable rear camber arms
Alloy rear cradle bushes
Extra lock spacers fitted to steering rack
Brakes
5 stud conversion carried out, with r33 lower arms, s14 hubs, new bearings, R32 GTR calipers and disks, and r33 booster
Misc
Hicas removed
Also car will come with all stock bits i have, standard suspension, 4 stud parts and brakes, front bar, all the air con parts
Will be sold with stock 33 wheels, Not the wheels in the pics
car rego'd till april08
All power mods, suspension and brakes have been done within the last 12 months
Reason for selling is the fact i've just bought a track only car and need something that will tow, i'll be sad to see it go, i love the car.
Located in wollongong NSW
Call or msg Glen 0410466635
$12000 neg
or will consider trade for 33 four door or similar
Edited by CEF33Y
https://www.sau.com.au/forums/topic/189538-a31-cefiro-manual-turbo/
couldnt ya pm him rather than spamming the thread.
anyway, this car is awesome. sounds insane. not quite as insane as selling an A31 to buy an S14 but anyway.....
is mega cheap for the amount of work its had done.
if you want a super sexy machine thats ready to drift buy this!!!!
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
