hey guys and girls im just wondering if any of u have heard of this sticker before it says now racing then in smaller letters it says nissan prince chiba racing team. i thought if it was a dealership i thought it would be on the windscreen and usually just a simple made sticker. mine is on the rear of the car on the boot on the right ill post up a pic. its probably something lame anyway but i was just wondering if anyone had herd of it. one more thing did any skylines come with gold writing like mine does in this pic or did the last jap guy buy or make em himself. thanks in advance.
https://www.sau.com.au/forums/topic/189541-a-sticker-on-my-car/
haha I wanna see James browse through icanhascheezburger.com for about 10 mins. I reckon his head would explode from the bad grammar.
Now Racing is Nissan Prince (chain of Nissan dealers around Japan) Tokyo/Chiba's racing team. Your car was probably from the Tokyo area and serviced at the Nissan prince workshop.
here's the R33 they used to run:
thanks for all your help. this forum is the best because you will definately get an answer and everyone are so helpful. im about to join so i can go to events and meet you all and check out some awsome skylines, most of my mates don't like cars and the ones that do love holdens or fords and a couple others love gemini's. apoligies for the bad grammer i tend to just type and send, i should probably check over it first.
dont get sucked into it scott! they like to lull you into a false sense of security and when you rock up to their meets and cruises... slap u around with a wet trout for hours on end... its sad... ive seen it happen too many times.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
