There may be an easier way but a mechanic I used to work with gave me a suggestion.
You will need a clutch alignment tool or something that fits into the spigot bearing fairly tightly (wooden rod) and some grease.
Pack the inside of the spigot bearing with as much grease as you can.
Now get your alignment tool or the other thing that fits and push it into the bearing.
Push on it and the grease should force the spigot bearing out as it has nowhere to go.
May get a little messy.. but it should come out. It was a while ago but I'm sure this is how my mate and I got his out when changing his clutch. I can't really remember it so hopefully that's a good sign that it was quick and easy.
Last one I changed, packed it full of bearing grease, used a wooden dowel that was a close fit inside the bush, and just tapped it with a hammer and the hydraulic action of the grease on the back of the bearing popped it out.
Easy.
  • 3 weeks later...
  • 1 year later...
Im a mechanic and have done this many times. Obviously, a Spigot bearing puller is the BEST way to go, but its not common to have one. What I do is similar to the methods mentioned above, but a lot less messy. Get yourself a punch, or rod that has a snug fit through the bearing. Instead of grease (as mentioned above), grab yourself a handfull of toilet paper (yes....you heard right). Tear bits off, wet it, push it in the hole, and use the punch to compress it. Continue doing this and the bearing will eventually pop out from the pressure that the bog roll is exerting from behind.
As i said, I have used this method at least 50 time over the years, and it has NEVER failed me......
yeah, grease is the best way. especily if its rooted.
i fine a 1/2" extension fits good inside it. pack it with grease and hit it with a hammer hard. might take a few gos but it will come out :P
grease is my preferred method...but if it doesnt budge run a 2mm drill into it along one side and use a small cold chisel to break it along the drill hole. A large screwdriver should then be used to remove it.
My spigot bearing was chipped the last time i put the box back on, which resulted in it being noisy.
How long can i drive with it being noisy like this? If the noise gets worse ill obviously have to fix it, but in the meantime?
Sounds like a straight cut box at the moment lol
when i did a manual conversion to my mates 32 4door i got a nut that was a firm fit and tapped it in with a hammer then tack welded the nut to the spiggot bearing then threaded the slide hammer into the nut and bang bang it was out, we tryed the grease method and it ddnt work it wouldnt budge. i found that was quite an easy way. also NYTSKY if u leave it too long like that it mite wear a grove in ur input sharf to ur gearbox, then its rooted.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
