Fs: Gizzmo Launch Interface (ign Cut), Gizzmo Shift Light, Adapter Loom - Plug Straight In! (all Rb's)
Item: Gizzmo Launch Interface (IGN Cut), Gizzmo Dual stage Shift Light, Adapter Loom for RB25 (will most likely fit a RB20 and RB26 too)
Age: 3 months old
Condition: Like Brand new
Price: $420
To Fit: (What car) This will fit a RB25, but I am 90% sure it will also fit a RB26 and RB20, will check and get back to you.
Contact: Via PM or email. PM for email address, or post in this thread.
Comments: This works 100%. Used it in my RB25 GTS-T and worked a treat. I could make 10psi of boost with my GT3076 at 3500rpm in neutral.
Shift Light setup is so damn easy, as is the launch control RPM setting.
I have made a couple of modifications:
1. I have added the option of a clutch switch (this requires 12v power). There is even a plug that will plug into your existing clutch switch under your dash.
2. Adapter loom - This is worth $180 (part of the package). Its soldered all ready to go. Just plug it into your factory harness and set it up, and off you go.
Also, this shoots some good flames when RPM cutting :D
Please feel free to ask any more questions.
Here are the pics:
New, I paid $440 for the Launch interface, and Dual stage Shift light, and an extra $180 for the adapter loom. Then I spent about 2 hours making the loom up and creating the clutch switch circut.
Thats a total of $620 plus labour to install this (could be nearly $800 after installation).
I'm selling for $420. I'll shout postage.
thanks.
Edited by The Mafia
Pretty keen to know the above meself
Have the launch control interface but not the shiftlight yet sitting on the shelf at home
If you can do a bit better on the price pm me
its a Field One touch connector. Same connector I use to re-wire so that I can make a RB26 Powerfc work in a RB20 and RB25.
I can't really do any better on the price because:
Launch Interface and Shiftlight: $400
Field one touch connector: $180
Two hours for me to make the adapter loom:$0 or someone else ($150)
Brand new you're looking at $700+ for this.
  • 3 weeks later...
btw this is sold to me, works a treat! Thanks mate
throw flames? I'd possibly be interested in something like this down the track...
  • 5 weeks later...
Hey mate, I'd be interested in the loom and connector as I have one of these on the way.
  • 4 weeks later...
very rarely.. but they updated the firmware so its not so violent anymore.
Can you please explaing to me in detail what te Gizzmo Launch Interface does? Kinda lost..
Edited by Dush
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
    • Any recommendations for what would be the easiest welding type to start on, for sheet metal rust repairs and maybe some exhaust piping too? Seems like MIG is the most common. Would gasless MIG be ok to learn on and do some simple jobs? I have a stick welder which has a Lift TIG setting, but i'm more interested in getting whatever's easiest to do, and most suitable, rather than using what i have.
    • Is the UP Garage in the US of Ayyeee even the real UP Garage?
