Cf Eye Lids For R32,r34, S14 & Jza80 Supra
hey guys, would anyone be interested in CF eyelids for either of the above mentioned models?
[r32,r34,s14 s1 and jza80 supra]
r32 similar to this but in cf
r34 (C-west style)
rough pricing atm will be $140 + $10 delivery or pick up in syd.
note: this is just rough pricing atm, i will know exactly how much it will cost when i find out how many ppl are interested. may be a bit higher or a bit less so keep posted, ill update once i find out.
i am getting this done through a supplier in Hong Kong. for this to go head, i need a $50 deposit to secure your spot so i dont get any time wasters + left over eye lids due to ppl backing out. the rest of the amount is to be paid once the stuff is ready to be delivered (i will notify when this is to be).
start date: 17/10/2007
end date: 7/11/2007
if this goes well, i may be organising a group buy for cf hoods & rear boot lids.
Edited by whyte
I would be interested in them for an R34.
As long as the quality is good :D
Will the Carbon Fibre have the gloss/top coat over it like the bonnets do?
Hey mate, of course it will. it will have a nice glossy finish that looks good and also protects it.
cheers
Not trying to be disrespectful or anything but are these coming from the same guys that are selling them on ebay for like $70 delivered..?
It's just that they popped up only in the last couple of days too..
Edited by so_tred
The $70 ones are Fibreglass...these are the CF ones which are slightly dearer..
Wrong buddy... :)
Take a look for yourself...
Carbon Fibre Eyelids on ebay
narh its not the same.
im assuming this isnt going to go ahead as not enough interest.
thanks
pic of r32 eyelid at the top is the one i took off ebay as i said its "similar style to this"
Edited by whyte
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
