Item:
Near New F40 Brembo Calipers with alloy radial mounts for an R34, with 340x32mm 2piece rotors (Biot) and braided stainless steel/teflon brake lines
Near new, still with original set of pads which are about 75% worn
Condition:
Very good, rotors have some surface hazing but are still 32mm as measured with verniers. As mentioned above the setup is still running the original set of pads so wear is minimal. The rotors come with brand new hat installation kit.
Price:
Asking $2,550 ono
To Fit: (What car)
R34 GTt, R34 GTR. If you put a bush in the radial mount to suit the smaller mounting bolt then the setup can also be used on S13/14/15, R32/33 GTST/GTR
Melbourne
Comments:
The spend on trying to lift the ante with regards to speed of my car has killed my interest in it. Too much money has to be spent elsewhere to get the car up to scratch so selling the gear that was going to help me get there (RB26, turbo setups, brakes etc etc) so calling it quits while i still have a few dollars to my name and a semi functionining car.
Photos when i can steal a camera from work and be bothered unpacking them.
https://www.sau.com.au/forums/topic/189610-r34-340mm-brembo-f40-setup/
Probably about the 16th....but car is going back to std. You GTRs guys were right. I was wasting my time with my GTSt :P
???? :P
i should reach through my computer and slap you!
are these a set of front and rears? I assume you will need wheels with big brake clearance for these puppies...are they a straight bolt on to R34GTT?
Only fronts. They will fit inside most 17" wheels with an offset of 35 or less. They are straight bolt on for an R34 GTT.
I love my GTSt, and it has been a great car and in my eyes quick to boot..only routinely tracking any car can get expensive, even my humble GTSt. So its time i focus on some other things for a while rather then trying to annoy GTR drivers...but she will be back, better then ever in a year or so time. :worship:
  • 1 month later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
