Im sellling this setup due to another project in progress.
PHOTO CAN BE FOUND ON EBAY!!!!!! Item number: 190163797211
The parts inlcuded for sale are:
- RB 20 head (worked)
- Big cams - 272 deg
- Greddy adjustable CAM gears
- Competition valves and springs
- Turbo GT 3540 0.86 rear housing
- Walbro IN TANK fuel pump
- Tial 38mm external wastegate
- high mount exhaust manifold
- dump pipe included (NOT FULL SYSTEM)
- Custom fuel rail
- 660cc bosch injectors
- intercooler and piping - also piping to airfilter (off front of turbo) not shown in photo.
- Front facing plenum and throttle
- Microtech LT12-s (included on the computer is a tune for standard RB20 bottom end making 375 HP at the rear wheels)
This setup is all that is required to turn your R32 into a real weapon. Save yourself time and money work has already been done by reputable performance mechanic. Very cheap considering the parts and labour costs....
Any enquiries you can enquire on 0424 352 862 - Set up is off the car and can not be seen running. (if does not sell will consider selling parts seperately)
I Want 5000 For the whole Setup MINIMUM it owes me alot more then that. All parts bought new and barely done 1500 k's.
