Im in the market for a new set of fronts as my previous set have worn down to the radials on the insides. Wheel alignment is as per Sydneykid's directions. But iv hit a dillema between cost and looks.
Now the tyre i had on there was a 235-40-R17, which was quite fine. Only complaint i would have is maybe that it didnt make the rim look quite as big as id hope as the tyre generally sits more squarer. But now that i have to replace them iv hit a snag. Previous tyre was a Kuhmo ecsta. On the rears i have Hankook K104's which iv been happy with
Do i go with the same tyre as i have on the rears but on the front and the same profile etc etc. Or do i go with a better tyre but say with a 45 profile instead so that i save money on the profile to get a little bit better rubber. In addition to that, should i go with a higher profile, but smaller tyre (say 225) so that it stretches to minimise the "squarer" look, or even keep the 40 profile but get a 225 to give it a less squarer look?
What would be the best option to reduce this sqaurer look, but also maintain as much striaghtline and cornering grip as possible...Any help would be greatly appreciated! :D
https://www.sau.com.au/forums/topic/189650-new-tyres/
to be honest im having a hard time understanding what exactly ur after, but if ur after a more stretched look go a thinner tire, u want the tire to be smaller on the rim get a lower profile, both of which will probably affect handling negatively. for a 8" rim which i assume it is, to get a stretched look go maybe a 205/45 or 215/45 tire, or if u want go to down in profile get maybe a 205/40 or 215/40.
https://www.sau.com.au/forums/topic/189650-new-tyres/#findComment-3417988
I'd stick with 45 profile for anything under 235 width or it'll look like the wheel/tyre is very undersized and doesn't fill the guard properly. My current set of rims came with 215/40/17 tyres and they looked tiny compared with when i swapped them for 215/45/17.
https://www.sau.com.au/forums/topic/189650-new-tyres/#findComment-3418542
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
