Hey,
Im looking at replacing my standard fuel pump in my R34 GTT and was wondering as to how good the nismo pump was? When installing, is it a direct fit without absolutely any modifications needed, for example is there any need to modify the cradle?
Also which is considered better by people the nismo or the tomei?
Cheers...
https://www.sau.com.au/forums/topic/189678-nismo-fuel-pump-question/
+1 for nismo, i mean on my 33 all i had to do was pull the whole stock pump out and replace it with the nismo one, no mucking around ;)
while looking at nismo and tomei, they are both direct fit/replace but i like nismo more :worship:
You already got a yes to that question
So YES, get it
Reason 1) your oldie might just make it but that's not good enough for a performance vehicale, should be able to do what you want with ease which the Tomei/Nismo will
Reason 2) The oldie might be nearly dead, Get a tune, all good then 2 weeks later, lean out and bang!
The Tomie and Nismo should be the exact same part nunmbers from whatI've heard and the Tomei is prolly $50 cheaper so just go for that.....
But of course, the choice is yours :spam:
Oh, and in case you're going to ask.....You will NOT need an aftermarket Fuel Pressure Regulater..Period
:closedeyes:
:closedeyes:
:spam: I spoke to both CRD and C&V today and they both said get the pump but make sure u get the regulator also cause u got stock injectors???
