Nismo Fuel Pump Question
MR R34
 Share
Hey,
Im looking at replacing my standard fuel pump in my R34 GTT and was wondering as to how good the nismo pump was? When installing, is it a direct fit without absolutely any modifications needed, for example is there any need to modify the cradle?
Also which is considered better by people the nismo or the tomei?
Cheers...
+1 for nismo, i mean on my 33 all i had to do was pull the whole stock pump out and replace it with the nismo one, no mucking around ;)
while looking at nismo and tomei, they are both direct fit/replace but i like nismo more :worship:
You already got a yes to that question
So YES, get it
Reason 1) your oldie might just make it but that's not good enough for a performance vehicale, should be able to do what you want with ease which the Tomei/Nismo will
Reason 2) The oldie might be nearly dead, Get a tune, all good then 2 weeks later, lean out and bang!
The Tomie and Nismo should be the exact same part nunmbers from whatI've heard and the Tomei is prolly $50 cheaper so just go for that.....
But of course, the choice is yours :spam:
Oh, and in case you're going to ask.....You will NOT need an aftermarket Fuel Pressure Regulater..Period
:closedeyes:
:closedeyes:
:spam: I spoke to both CRD and C&V today and they both said get the pump but make sure u get the regulator also cause u got stock injectors???
a fuel reg is only to max out your injectors .. its useless on a stock turbo .. if your using a aftermarket turbo or high flow with stock injectors (not advised) then you'll need a fuel reg
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
