Hey all, just wanting to get some opinions when its best to have a second battery to run your system, ie what components you can run comfortably using the single battery before it becomes a problem,
also,
what would it cost to get a second battery installed somewhere (roughly)(chris?)
and what components you would run off each battery, say the head unit and speakers off the main battery and the subs and amps from the secondary? or something like that.
Steve
https://www.sau.com.au/forums/topic/189724-when-to-get-a-second-battery/
also,
Steve
i have 2amps 4speakers headunit and few other things running of one battery and its been fine... just get a volts meter installed and you will be able to see what you are using.. just dont listen to music with your car off for more then 5mins :worship:
Yep, agree with Haysey. If you like to listen to a lot of stuff with the engine off, a good deep cycle battery will be enough, even with a few amps. Even a normal car battery (good one with good CCA and RC) should be fine if you don't listen to the stereo with the car off much. Make sure your ground wires are good including the alternator to battery cable.
Fixxxer
Fixxxer
What about for people who are hitting about 3kw?
Like the other guys are saying a big deep cycle will be fine for most applications. However you're looking at at least $300 bucks new for a shitty one. Id go with something at least 500CCA.
If you want two battery's, you keep your standard battery and get a secondary deep cycle with whats called a "dual battery isolator" they're about $150 bucks.
What happens is when the first battery gets to 50% it swaps to the deep cycle but at the same time it charges both from the alternator.
If you know someone with an AMP meter test your battery load with everything on full and that will give you an indication of what battery you need.
I myself have a Van with a decent system around 140DB and at max volume is drawing 60amps from the battery, the thing is, its a diesel so it has a 60amp alternator which is pretty big and only just keeps it afloat. I think skylines have a 35 or 40amp or something?(correct me if I'm wrong) So you don't wanna be drawing more then your alternator can charge or you battery will be f**ked quick smart. If its not a deep cycle and you flatten it more then two or three times they are just about f**ked and won't hold a charge.
2c
ah ok, so how much am i looking at for a decent deep cycle battery? to be honest, the most i can see myself running is 4 speakers, 2 amps and at best 2 subs with a double din dvd unit
i would like to be able to listen to tunes with the car off, well, id like to know that if i did the battery wouldnt die, not that i just get in the car and listen to music for the hell of it...
but for peace of mind anyway
You are looking at spending at least $300 anything under that is not worth the plastic its made from.
I can get you one through a distributor. I buy all my batteries from them they are top quality and i highly recommend them as the guy that runs the business sells allot of solar battery boxes and stuff to fiji etc and is a qualified electronic engineer (he knows his stuff)
PM me for more info.
I'd be considering an earthing upgrade + bigger alternator before a second battery, no use having 2 batteries if you cant charge em.
As Trav33 said...the guys that did mine just recommended a better than standard battery and a bigger alternator. As it is, it is running fine on the standard battery and standard alternator.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
