Ok so this is from my 260RS diff (LH Side). Does anyone recognise it from something else?
DIMENSIONS :
31.5mm diameter across splines
33mm diameter across middle section
35mm diameter across base of shaft
Spline section is about 40mm across the overall shaft length
31 teeth
155mm long overall
Does anyone by any chance have an R32 GTR or R33 GTR they can check?
It doesn't need to be the 6 x 1 flange as I'll change axles anyway. Basically I need to figure out the LH side so I can change both or find a RH side as I simply don't have it. This is so I can match the rear diff with the front 4.111
I am trying to avoid having to change my rear hubs to GTR
Thanks
https://www.sau.com.au/forums/topic/189737-260rs-diff-query/
260RS diff is R33 GTR diff. So are the axles.
The only R33 GTR diff I had to compare against was an Active Differential type (which was definitely different) so you could well be right. To be honest I had always assumed that 260RS was R33 GTR but I suppose R32/R33 output flanges could be the same.
Ive smashed my front diff (rear is still good) so you might want to look at that too.
I'm already running the 260RS front diff, hence why I need to change the rear to match it.
R32 GTR output flange is close enough that I could probably use it. On a whim seeing as they are also R230 I tracked down some 300ZX TT output flanges to compare against, as you can see they're quite a bit different again
Dammit. I meant to say output shafts the same, not the axle shafts... My bad, sorry.
Oh ok, so I need R33 GTR output flanges then, thanks for that ;)
EDIT : I can confirm that yes they have the same part number. Cheers Psy
On the subject of R33 GTR. Can I use this :
Its an active differential. These apparently came out in some R33 GTS25T's aswell. Has anyone ever retro-fitted one of these to there Skyline/Cefiro etc. Can anyone forsee any problem?
Edited by tRUkbOY
Well I have it all sorted now, my R33 GTR RH Output flange is on its way from Japan.
On top of that I sorted my axles and I don't need to change my hubs to GTR/260RS spec either. In case your wondering, no I am not going to use my piddly RS-Four axles nor am I using axle/diff adapters.
It was (in the end) all very easy. If anyone is interested I'll update with photos when my Output flange arrives in 2 weeks.
you guys are crazy with your GTR setups
SIMPLE solution
S13/14/15/y33/y32/gtst/r32/r33/
all the diffs are interchangable
you might not have mounts for the attessa shit, but you can make them
I have an s13, with WGNC34 rear cover, s14 solid diff mounts, and Nismo 2 way
swap the input shaft for the driveshaft from teh C34 to the s13 diff, bolt that ish up
throw some greddy or veruspeed gear oil in there and your good to go guys.
just make sure you get the output shafts wit hhte same number of bolts (6 i think?)
SIMPLE solution
Yup, I know. I work for a Nissan dismantler :)
Yeah but in the end it seemed crazy for me to buy another diff (I'd already bought 2 others) when I had 80% of a GTR diff already. The flange only cost me $300 & now it bolts straight in and includes the mount for the ATTESSA pump. The axles were easy (don't believe what people tell you) and I get to have a mechanical LSD as opposed to Viscous
So what is the final parts needed?
Diff?
Output shafts?
LH and RH axles?
Anything else?
Diff?
Output shafts?
LH and RH axles?
Anything else?
For me personally? CV grease & LSD oil. Otherwise I'm not quite sure I understand the question Darrin...............
EDIT : Sorry, I just read further up the thread. I'm fitting it all on Saturday so provided I don't run into anymore issues I'll post the full diff swap with pics on Sunday
Edited by tRUkbOY
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
    • Hi Luke, haven't thought about it a lot, trying to get the car into the paint shop first.  Did you want to make an offer? As stated above, I'm just looking for fair market price.
