Due to some modifications to my car (R33 GTS-t), We have hooked my thermo fan to switch on when a certain temperature is reached.
The Problem
the A/C blows cold air onto my feet when the the AC is switched off. We have fitted a diode so that it doesn't send an electric signal to the aircon
however it still blow air.
We even disconnected the aircon and now it just blow normal air.
This only happens when the thermo switches on once a certain temp is reached.
Any ideas how to solve this problem?
Edited by 33_skyline
https://www.sau.com.au/forums/topic/189740-aircon-turns-on-by-it-self/
take it to an electrician dude, sounds like youve made the a/c earth when the thermo comes on :)
my stock 33 series 2 blows air at my feet when the control is off, which is annoying but i dont think its air conditioned, just the fan blowing
still annoying i cant control it tho
take it to an electrician dude, sounds like youve made the a/c earth when the thermo comes on ;)
I will let the guy doing all the mods to my car know and he will check that, he has done the majority of the electrical work.
won't go to an auto electrician last time they disconnected wires and hooked them to the wrong place, we found out when tuning it
and the ecu had heaps of errors & warnings.
that is something to remember though mine is no longer stock and it is
diffently aircon cause it freezes my feet, but yeah same problem.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
