IM YELLLING AT YOU FLICK.
I DRIVE THE WHITE AND BLACK R32 SEDAN.
IF YOU DON'T KNOW WHAT IT LOOKS LIKE HERE IS A PICTURE I TOOK EARLIER.
I believe u were chatting me up at the last drift prac.
HEHEHEHHE
Hopefully i sort out my spinning issues.
Brenton
Ill be out watching and taking plenty of photos, hopefully with my new SLR digi by then, so yell out if you want some photos, just let me know which car you're in
hey Flick ill be in the black r33 coupe there shouldnt be any other black r33s out there so it will be easy for you to find me but if not then its the r33 with the red drivers seat and ill have r33 stockies on the back and mags on the front hope that helps you find me a little easier cheers mate
Edited by skyline.
im sure she will take plenty of pics of all the skylines out there anyway lol.
Well ill be out there, but some people dont class my car as a real skyline so dunno if ill help make up the numbers for the skylines :D
U better be prepared for that little purple thing ryan.
it may look old and haggered but dam it skids very easily.
Hey bud, you wont even reconise the car when Iam finished with it, getting full respray and lots more goodies!! :sorcerer:
Ryan
Lol brenton nice photo :) and cheers for yelling at me :)
Chatting u up? ssssh dont tell them all that! Luke might get jealous :)
Nah lukes right, ill probly take a million pics of all the skylines anyway, but ill make sure to pay more attention to particular cars then :)
Hey fella's ill be there hopefully in my blue r33 :)
Just in the process atm of getting my cams, filled in the paperwork.
If anyone has 2 or 4 cheap stockies for sale let us know!!
And also, kinda on topic. Im buying/ordering a new clutch this weekend. Any recomendations? Got 190rwkw. Want to dump it and last. Got $550ish to spend. Was lookin at some exedy button thing rated to 260rwkw.
And last thing, lol. Where/what type/ how much is a helmet suitable for mallala's requirements. Just wanna cheap one for now.
Thanks, Jack
HAHAHAHA
Ryan: You better thrash that thing Like matt did.
Lee: You know I luv ya.
Richo: Shot Gun Following u buddy:
Vietorious: You live down the street from me don't you.
Flick: OH BABY OH BABY. HEHEHEHEHEH.
bluegts: Go to Autosport on Magill Road. They sell Open faced ADR/ Cams approved helmets for $80 i think.
Ummmmmm also please dont forget to bring extra fluids, especially coolant. Will be hot out there.
hey bluegts aka=jack i have a opend face helmet you can have cheep as like i dont know 20bucks ore something its a australian standard one you can use it at mallala ill have it waiting for you in the december drift practice if you want it the helmet is used and stuff but it is perfectly fine few scratches but nothing majour its up to you mate let me know if you want it cheers :Trent
Edited by skyline.
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
