Hi all,
Just a quick question, I recently bought a 3" greddy power extreme II cat back exhaust system with a 3" front pipe, the thing looks great and really isn't that loud (if compared to whats around) but has a nice grunty sound when you accelerate(not a droning noise), Now I thought I would be Pro active and go to an exhaust outlet that is a EPA approved noise tester and get a noise test done to my exhaust at EPA standards, just to see how I would fair, to my dismay the exhaust had a sound pressure reading of 93db(a) (90db being the legal limit), just 3db over the limit !!
Question: Is there anything that can be done to easy that sound pressure down a little?? any tricks of the trade?? can the exhaust be wrapped to help deaden the noise ? or is there anything else that might help drop the sound pressure down just a fraction? please help ....
PS Please dont post stupid obvious responses like, put your stock exhaust back on, or you will get a public :dry: for your troubles...
Thanks all.
Edited by immortal^
ok this might sound stupid (and i wouldnt recommend for street) but my freind put some steel wool in the zorst to clear EPA...basically took ALL the sound out (and probs kept all the exhaust gases in)....a silencer will do the job easily
I wouldnt worry about it that close, theres usually a tolerance allowed for machines such as these i.e. as a result of other noise interferance, position when taken (wave patterns/nodes cancelling in/out), plus more. I would say +/-5% easy which would make your exhaust comply with EPA
Otherwise, stick some steel wool in there, it will deaden the sound enough to pass a epa test and will burn out after about a week. Doesnt harm exhaust at all..... o/wise goto motorbike shop and get internal fibreglass baffle to suit 2 stroke muffler and stuff that in there (you'll have to dig that out cos it wont burn like s/wool)
Unfortunately if you wrap the exhaust you'll just force more noise out the back straight into the device :thumbsup: (it will make it quieter in the car for you) only way to quieten it is improving the internal baffle (increases turbulence) hence above.
Alternatively you may be able to buy/fabricate a restrictor for your muffler. These fit into the tip and increase backpressure at the outlet causing the sound to bounce back into the muffler, in turn cancelling some frequencies and disapating more noise through the baffle
all these methods will increase your backpressure obviously and decrease your peformance at high rpm.
fit a restrictor in between pipe one and two. Tkes less than 2 mins to remove and replace.
think normal gasket but with a 2" hole instead of a 3" hole... works a treat for epa noise testing :)
Well your wrong there unfortunately.
93 is 93. There is no "variance" allowance. Never has been.
So moving on, you probably need to look at changing a muffler to a better one.
3db is reasonably easy to knock out and keep it flowing.
Hell my 3.5" made 93db aswell, so easy to get it a bit quieter with a better muffler or whatever.
You can weld in restrictors, but thats a pin in the ass each time. Although with 93db its highly likely that you wont be pinned.
I wouldnt worry till you get the letter in the mail as 93db is much quieter than the usual 100+ systems that most people have.
A guarantee you rekon? I dont think so.
I know a number of people who have installed hot-dogs thinking it would work... and in the end had little-to-no impact to the overall db, the 'drone' is affected more than the outright noise based on what ive seen
to get mine passed i made up a reducer in the back of the cannon , it slipped in side the tip had one little rivet up from the bottom to make sure it didnt come out during rego check , in steed of a 5 inch hole in the cannon it was like 3.5inch or something didnt look stupid , used another piece of ss pipe to go down the canno bout 3 inchs and then a bit of pate tig welded to the end of the 3.5 inch piece and then put it in the lathe to machine it round and bore the internal dia out. worked for me easy to take in and out , made an easy 5-10db difference that what i did any way cheers
I personally wouldnt worry, 93 db is exactly twice the sound pressure of 90db. 90 db is really quiet, to got my Z32TT to 90 db i had to bolt in restrictors and heaps of steel wool, it sounded like a sewing machine, and i didnt boost it as it felt terriable, just wait for the letter, and hopefully it never will.
PS the sound test is done not under load, thats how all the "factory" V8's and the like pass, hold them at a steady 3000rpm and their quiet(thats where the test is done), give them a stab, and they bark.
think normal gasket but with a 2" hole instead of a 3" hole... works a treat for epa noise testing :thanks:
+1
Really easy 5 minute fix to make the problem "go away" why its getting tested. I would only muck around with mufflers if it was annoyly loud. 93db isn't very loud at all.
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
