The time has come for me to sell my pride and joy, and to move on to other things.
1992 Nissan Silvia Qs
Engine/Driveline
Recent S14 SR20DE engine conversion
S13 ECU and loom
S13 manual gearbox
A'pexi pod filter
2.5" cat-back cannon exhaust
Exterior
180SX front conversion (Onevia)
Full respray in jet black
Unique front lip (one of a kind)
Nismo side skirts (rare)
Nismo rear pods (ultra-rare)
Spoiler removed and holes welded
Personalised black number plates to match the paint scheme
Interior
180SX Type-X seats
Digital climate control
Custom 180SX 'lazy-eye' headlight switch
Pioneer head unit w/iPod direct control + Pioneer speakers
Momo Corse steering wheel
Aftermarket pedals
Nismo shift knob
Exedy Sports Organic HD clutch
Strut braces front and rear
Wheels/brakes
17x8" +35 offset JWT lightweight racing rims (made in Japan)
DBA slotted rotors
Lucas brake pads
Pirelli tyres (front) and near new Nankang tyres (rear)
Other extras:
Quality 3 point alarm + immobiliser
S14 in-cabin VTC switch
Long registration until September 2008
140,000kms on chassis
Estimated 80-100,000kms on engine (came from an S14 with automatic transmission)
History
I purchased this car as an almost dead-stock Silvia in March 2006 from a SilviaNSW.com/NS.com member with 118000kms on the clock. It was previously a SEVS import, not a 15 year-old rule shitbox. I had saved since I was 13 to purchase the car. Since then, I have spent thousands (more than I spent on the purchase price of the car) modifying this car to make it one of the cleanest and best-looking non-turbo examples around. Nearly every cent of my wages went towards this car.
All work was done professionally as well. Nearly all receipts have been kept for parts purchased or work carried out. The paint work was done at RS Performance in Moorebank, the mechanical work was done at Safer Steering in Crows Nest, and the alarm installation done at MetroSound in Artarmon. The only major thing I did myself was the Onevia swap, with the help of SilviaNSW.com member Arkhaeon.
During my ownership, I have treated the car very well. Unfortunately, a month or so ago, the oil filter fell off whilst driving at 60km/h, draining the oil and doing a fair bit of engine damage. This was due to my mechanic thinking that the S14/S15 oil filter was the same as the S13 one! Thus I opted to go for an S14 SR20DE transplant. The S14 SR20DE has more power and the Valve Timing Control function (VTC, NVCS, or VCT depending on who you ask...). There are a few forum members running these non-turbo engines, and one particular member who is running 130rwkW from an S14 SR20DE with fairly minimal mods. As a P-plater car, this would have to be one of the quickest and best-looking options available.
Condition notes
NO accident history. I have thoroughly inspected the car during the Onevia conversion, there are no signs of bent chassis rails or a mangled radiator support, and the panel beaters who did the respray agreed this was one of the cleanest and straightest S13s they had seen.
The respray was only done in July so the paint is still in excellent condition. However, there are a few scratches from road debris and so forth.
Originally I had the car painted with a Vertex rear bar, but I decided that it didn't suit the lines of the Nismo side skirts. So I recently opted to get the factory rear bar repainted. When at the painters, someone knocked it off the rack as the paint was drying, so it has a few drips. However, I didn't have the time to get it repainted. I can organise for the buyer to have it resprayed very cheaply there. The drips are barely noticeable unless you are close.
The new engine was taken from an S14 SR20DE and installed professionally. I've retained the S13 manual gearbox.
I have decided to move away from the modifying scene for a while, and buy a more stock car. So I may be interested in a swap for a non-turbo car.
Contact details
If you are serious about purchasing the vehicle and would like to arrange an inspection, you can contact me (Pete) on 0409 000 056. If I don't answer, send me an SMS as I'm most likely at work. I do not like time-wasters or tyre-kickers.
I am located in Cremorne (Sydney).
Price: $10,500
Lowballers/teenage dreamers will be ignored. Try finding a non-turbo S13 this clean and tastefully modified.
Please note that this picture shows the old Vertex rear bar - car currently has ultra-rare (and sexy) Nismo rear pods. More pictures to come next week.
  • 4 weeks later...
    • Sounds like the rack seals blew.
    • ^ This is all good advice. I can imagine that there's some passive components in the HVAC controller that run that PWM output that could die, or suffer bad solder joints. It can be worth opening it up, taking a schmooze around looking for swollen electro caps, evidence of liquid escape anywhere, tracks that have been hot, lifted, cracked, etc. A DMM might not be suitable for seeing if the PWM output is pulsing. Might be too fast and too low voltage for a DMM to keep up. An analogue voltmeter might give a better hope. I use a handheld oscilloscope (<$100 from Aliexpress if you want something cheap). A DMM might see the voltage across the motor flicker. Otherwise, as above. If you can successfully see PWM action, then the control side should be good. If you can't see it with what you have, you might need to step up the instrumentation used, as above. Beyond that, and dbm7's advice on testing the motor directly, you're down to looking for broken wires, corroded connector pins, etc.
    • So Thanks for the comments etc. To follow up on this, we went down the path of fitting a divider down the middle of the external pipe that was added to the exhaust manifold and the divider went from very close to the external wastegate all the way up to the "V" part where the pipes from each side of the manifold joined. After this modification it was finally in a position to do the dyno-tune with some degree of success. Top end power was down about 10kw (250rwkw down to 240rwkw) I believe from previous but it seems to be more responsive lower down and at least it is now driveable and fun and back on the road to be enjoyed. Apparently the timing couldn't be run the same as it was running into knock and boost was down about 1psi. For all we know this could have been from the fuel being a bit older, or perhaps some slight complication from the new head gasket as we didn't have compression figures from before that mod to compare. I'm no mechanic and this is second hand info but I just wanted to follow-up to those that commented or read the original post with interest. After so many months of stuffing around this is a big win. The interesting part was most of the info around this was gained from information around Barra motors and not GTR as the manifold setup on the Barra with single turbo was more similar.  Thanks for those that helped with info. Regards Rob
    • G'day ... first up, I very much doubt that's a resistor network (as used also for this job), but the part# looks right. The description of 'power module assembly' looks to be nissanese for 'PWM driven, ground switched, DC motor speed controller'.... the circuit in the schematic kinda infers that's the case... ...with the transistor symbol appearing in the unit described here as 'Fan Control Amp(lifier)'....being driven by pin20 on the HVAC unit,  and a feedback signal on pin19 from the motor negative terminal for some reason (might be motor fault detection, maybe they detect commutator switching to determine motor revs as well, I dunno)... but if they are  counting commutator spikes, a bad segment (or really worn brushes) will throw a spanner in the works... The motor itself will as said be brushed DC with segmented commutator, rated at 12VDC nominally ~ now-a-days I just unplug them, determine the positive wire, and hook them up to a variable power supply and find out how much current they draw, if they work etc etc ...you can also check for bad segments...ie; set the power supply up to feed 1volt @ 2amp max, then watch the wattage count as you slowly rotate the fan blower motor through a complete revolution ; any bad/dead segments will be clearly evident...some folks would just say determine the positive wire, and feed it battery voltage, and if fan spin, you've got a win...<grin>... well, at least that infers it should do something when plugged back in, and the HVAC unit commands it to run... and if it doesn't, you suspect the module, but you should check the PWM signal on pin20 is actually present, and if it is, blame the module ...
    • Ah. OK. I take it back. I hadn't looked closely at the R33/4 arms and presumed that GKTech did as GKTech do everywhere else, which is to use sphericals there. The poly bushings are made to be 100% interchangeable, should use the standard bolt just fine. Every other bush in every other place in pretty much every other car, does.
