hey i just bought replica rs bov, for my '96 r33 skyline, and i put it in last nit at my mates, we drilled new holes onto the stock cross over piping, exactly wer the stock bov goes, and mounted it there with know problems and no leaks!
took for a few runs, adjust the hardness & softness of the new bov.. got it about rit..
so i drove home fine!
the only thing that i noticed was that wen down gear and clutch was all the way in, and i didnt release it, the revs would drop from 1500rpms to bout 100rpms, but didnt stall, and den went back up to normal idle revs, lik 500-600rpms...
PROBLEM:
so i got in my car dis morin, drove to my other mates place, who lives bout 2ks away, and was all fine!
then wen i left i got to bout 2000rpm, and it felt like it was bunny hopping! or sumthing??
MY MODS:
i just got a new (afc)apexi neo fitted and tuned,(at 500rpm/1000rpm my correction is -8%. etc..)
front mount intecooler, splitfire coilpacks, re-gapped .6mm spark-plugs,
turbo-tech boost controller/bleed valve, HKS 3" cat-back exhaust.
IDEAS:
new bov needs to tighten(all the way to hard setting)??
afc correction to lean?needs to be adjusted..???
afm??how often do these r33 afm fail, go fautly??
on the back of the bov's there a vac. line that connects to the intake manifold,
should this pipe be a certain min/max diameter, length? if so how long and thick?
any ideas would help...
https://www.sau.com.au/forums/topic/189771-r33-new-bov-driving-problems/
atmo bov's do that...leaks boost as u start to make it so drives like a b!tch....and revs go nuts wen u pull up at lights. look at ur bosot gauge and tacho and u know wat we mean...climbs n drops..climbs n drops...its tryna compensate for the leak
I'm putting my money on leak, I have had intercooler piping come off many a times, and anytime you try and put any sort of power down, it feels like it's bunny hopping...
Check your piping and schtuff :thumbsup:
a leak u reckon? best way to find a leak then????
wat bot:
would that make diff?
if it is doing it when you accelerate then you have a problem that. whether the bov is atmo or not shouldn't make a difference during acceleration, unless the bov isn't closing properly.
now the bunny hoping you are talking about, is it bad like a leaner driver, or is it more of a missifre? the fact that you are running 0.6mm gap plugs with splitfire coils worries me. do you have to run the gap that small to have it not missfire? if you do then you have a serious problem with the splitfires.
yeah, it happen wen i accelerate, and was only in first, and yeah, hit just over 2000rpm and yeah..started hoping!
i think i put it in second and it did it aswell round the same rpm..
now wat u mean by..
"bad like a leaner driver"
well my plugs + coilpacks r fine
and its similar to misfire..but feel liks no fuel..
fuel pump? afm?
i have no clue ay..
sorry, cant remember, it was early dis morin wen it happin..and i didnt have time to have a good look..
i tried turning down the valve to make it harder..but no good..
mit turn it all the way down..
but as for driving im pretty sure i was and had my foot down lik a normal driver, dont think my foot-slip or i was back-off or anythin..
i was just driving...lol
Yeah, wen i put my foot done it didnt pass 2 to 2.5k as i mention earlier..
it struggled for some reason..
but i did find my problem..
something 2 do with my apexi afc/neo!!!!!!!!!!!!!!!!!!
so i reset it and it drove fine..
well....it uses more fuel now..lol
so i adjusted the air-map myself just on low throttle. and seems to be if not better than before!
the first place i got my tune done, and the at the same time got my apexi NEO fitted..
they didnt change/adjust the DEC AIR or the THROTTLE %..
so i really just changed those..
and my low-throttle from 1,2,,4,5,6,7 and i curved the map..
at 3000rpm i left it 0%(so no changes) coz that wen boost kicks in..well round der..lol
and i dont want to lean it out der.
so i gota get a re-tune and coz it using a bit of fuel..
but has anyone got AIR MAP details?
im gona start-up another topic to c wat people setting ther afc air map set at...
Edited by bumble_bee
so.. i took ma car to speedworks in perth, they re-tuned ma afc..
it was oxygen sensor that was playin up!!
so they dis-connected it..and did the tune wit out it
doesnt stall at all anymore! and drives beta!!!
just still uses a bit of fuel..
thank god i work for nissan, and ive already got and put in the new o2 sensor..
but my 33 still chug's fuel..
speedwork had a hell different air map settings than ovaboost..
so i wondering, whould tuning an afc with the o2 sensor connected they re-connecting a new, make any difference?
or would u need a re-tune..???
Sounds like your mixtures were out and the cars gone into limp mode to try make it through the rest of the day. Should of got it tuned properly ages ago...
Mate your cars driving crap because of the style of BOV you've got. Excess air is vented to the atmosphere and not back into the engine (i.e. plumbback). The ECU has measured the amount of air coming into the system through the AFM and is ready to control the a/f ratios but as the excess air is simply vented out of the closed loop the ECU has simply lost it and mixtures are all over the place and the ECU is trying to compensate all over the place
na, my car is fine now since i got the o2 sensor fitted and lowered some of the % of the high throttle air map settings..
all good..i havent had that bunny-hop/learner problem since..
and i get around 400k's outa my 50L tank now,
so yeah..
and i still got the atmo bov connected..and my idle is fine..
i cleaned out the acc and i believe that made a hell of a difference ay...
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
