i'm looking to buy some coilovers with 12kg front and 10kg rear spring rates, has anyone here had experience with these as im interested in how stiff they would be, the coilovers also have 32 damper adjustments, so say the spring rates are too stiff, could you soften them up by using the damper adjustments, thanks in advance, the car would be mainly for street use by the way
Those spring rates are chiropractor stiff :happy: As in you'll need one if u do get them ;)
  • Replies 133
i've just installed some
tein circuit master type RA into my r33 with 10kg front and rear spring rate (racing springs as tein call them), i have yet to drive the car yet (due to not having a gearbox) but once i do, i will let you know what the ride is like.
i had previously had d2 coilovers which had a huge spring-rate and i found it drivable in street-condition abit bumpy and i got uses to it
Had RA's in the R32 and they were awesome, good damper control over the rates.
:wave: D2's......... shudder
Ive been running Tein Super Drifts for a few months, 7kg springs front and rear, in my opinion they are perfect for street (even on the crap N.Z roads) ,i have yet to try them out on the track, hopefully they wont be to soft!
A touch of realism anyone?
The standard spring rates are around 3 kg/mm. Do you really think that Nissan got it 400% wrong? I don't think so.
Those sorts of spring rates (10/10 or 12/10) are more than what we run in a V8Supercar, on slicks on the best track surfaces in the country. A road tyre is simply not designed to handle that sort of spring rate. Even an R type tyre doesn't like much over 7kg/mm.
To control those sorts of spring rates, the shock absorbers have to have BIG rebound (extension) valving, if they don't, the spring will simply oscillate after every bump, making the next bump even bigger. But it is actually even worse than that, the huge rebound valving stops the wheel dropping back down again after it has absorbed the last bump, so the tyre sits above the road surface, for some time.
If you truly think that you car handles well on those sorts of spring rates, then you are sadly mistaken. You will find out, when it is wet and it won't stop, when the road has slight ripples and it won't accelerate, when there is a bump mid corner and it won't hold the line. Or you will go to a track day and a guy with standard springs will kick your ass. Or you will go to the drags and a stock standard car will beat you by 20 feet to the 60 foot line. Or you will try and drag off a taxi and he will walk away while you wheelspin across the intersection.
Oh wait, there is more. Since the chassis wasn't designed for those sorts of springs rate you will soon find rattles appearing from all over the place, the electronics will have intermittent problems, the CD player might even skip a few tracks, cracks will start to appear around the spring mounts, globes will blow more regularly, suspension bushes will wear out at an alarming rate and you may even find some new cracks in the windscreen.
But hey, what would I know?
Cheers
Gary
Cheers
Gary
he is right alot of this stuff has happened to my car.
lol,
not saying what you are saying isn't true sydneykid, but why do most of the japanses timeattack cars running street-tires or semi-slick run big springs rates 10/10 or even more than that?
i havn't experience any of those things you have mention with my tein, maybe its because they have good rebound and damper control? im not sure all i know is that my car is handling alot better compare to my old setup.
Edited by [Michael]
not saying what you are saying isn't true sydneykid,.
so you agree then?
i guess i better get some wikkid strong coil overs to do hectic times in the "time attack uleh"
but why do people not look at the group buys SK has organised and notice the hundreds (? its alot) of ppl who have bought the bilstein stuff and recommend. it to any one they talk to? too many fast and furious street racers in here.
so you agree then?
excuses me...?
can i adjust the rebound and damper on the SK groupbuy Suspension gear? last time i check no. My car is being used prodomently for circuit work. So i've gone for a setup which has been proven to work in skyline which are used on the circuit.
Just because everyone does one thing doesn't make it right or the correct method.... Suspension setup depends on alot of factors like the weight of the car in question, other suspension compounds, the alignment setup etc etc. Just because it works for one person or hundreds of people doesn't mean it will work for me or be the best setup available
Also my comment on the time attack cars was just to point out that it is working for them, and im sure if dropping down to a 7kg spring rate would help to improve their times by even 0.1 of an second they would do it.
ALSO last time i check this thread wasn't asking about SK groupbuy or what a good suspension setup was, but if the selected spring rate would be too stiff for "scarface", and if the damper adjustment would make a difference.
so how about you keep your comments to yourself, as i dont see it contributing anything to the topic
Edited by [Michael]
Sounds like someone hit a nerve, I think its perfectly valid to talk about it.
so adjusting the damper rate changes the spring rate? whats the point then? to mask an innefective spring rate? or to make it comfy for the chix? i dont get why you need adjusting. adjusting comes in coilovers because they use one generic body for all their spring rates on their different cars. or does turning a small nob excite you?
lol look above - you said youve chosen to use what has been proven to work - now your saying your choosing to IGNORE what has been proven to work aswell - on the track AND the street.
dude this is the interwebs - since when does every topic in forums stay on topic? and who cares since im actually saying something that all the newbs on the forum who post up 1million times a day "is this coilover hecitc uleh?" might actually find of use. but if not meh
"lol look above - you said youve chosen to use what has been proven to work - now your saying your choosing to IGNORE what has been proven to work aswell - on the track AND the street."
ok i guess you didn't understand what i was trying to explain, most likely my fault. i did not ignore the SK groupbuy, i look at it and for the price and what it could do compare to the price of the tein type RA and what they could do.
i weight up the pro and con of many setups before i went and bought the type ra. so i did not ignore anything...
and to your comment about the damper and rebound adjustment, last time i checked many forms of motorsport used controllable damper and rebound in their suspension, so im guess their is a point to having it?
last time i check bilstein and ohlin, have damper and rebound adjustment suspension... have alook here this is suspension used in motorsport http://www.ohlins.com/Automotive/Products/...91/Default.aspx
i understand what you are tring to point out but some of your arguments are flawed
edit: i found a good link, give it a read it will explain about damper adjustment http://www.whiteline.com.au/default.asp?pa...faqshocks01.htm
Edited by [Michael]
but those examples are for people who actually know what their doing - have chosen a proper spring rate and are using dampers with a proper adjusitng mechanism to FINE tune their suspenion,
not noobs who buy a coilover with sic 15kgmm springs and say "o its too stiff" and wind it down to softest damper setting. - when they should have bought a lesser spring rate in the beginning.
i do agree with you
"not noobs who buy a coilover with sic 15kgmm springs and say "o its too stiff" and wind it down to softest damper setting. - when they should have bought a lesser spring rate in the beginning."
but not in those exact words :dry:
so in the end looks like we both think the same thing :D as i dont fall into the bracket of a noob going my coilovers are too stiff, as i am over the moon about how well my tein are :D the only reason why they are set of the softest setting is because i have yet to fine tune them, as i jsut got my car back onto the road :(
....but why do most of the japanses timeattack cars running street-tires or semi-slick run big springs rates 10/10 or even more than that?
scarface was asking if 10/10 was too stiff for the street <STREET> ... not some perfect track in Japan. Jap time attack cars are made for one sole purpose, when was the last time you saw the Mine's R34/HKS Evo etc. on a street? (hypothetically).
You are ignoring what Gary and Beersandwich are saying.
You might not think they (TEIN) are too stiff...but compared to what? What was your old set up?
I've personally seen how good Gary's bilstein/whiteline combo is and how smooth it looks on the street and at Wakefield. I've also experienced TEIN Super drifts, 7/7 with adjustable rebound...and I would pick SK's group buy over it without a doubt.
No matter how much adjusting we did to it (R33) couldn't put the power down when the road was bumpy, and over series of bumps the tires don't even make contact with the surface anymore. Of course they're better than the 100,000km old shocks/springs that were in it before...
I say compare your setup to someone in the WA who has installed SK's suspension package. If you think having good suspension is as easy as fiddling around with a little nob you are sadly mistaken...the fact of the matter is TEIN's are not suited for street use, and why would you want a ONE TRICK PONY. <that probably does not directly relate to you because you stated your car is a circuit car but please do not recommend it for street use>
James
my tein aren't too stiff...
if your in perth, i will be more than happy to take you for a drive to show you. my Tein's are suitable for street use, i have been driving my car on the street for the pass week, so i can run-in afew things, and i don't find anything wrong with my ride.
i never said anything about fiddling around with nobs make my suspension good, i merely mention that when looking for a suspension i wanted the option to control the damper and rebound of my shock, so i can adjust the coilvoers to suit my other suspension compounds and the track im racing on.
your opinion is tein are not suited for the street its your opinion :P and thats fine :D but from my personally experience i would recommended my tein if your looking for a hardcore setup which can be driven on the street, if you just want something for the street then it would be a waste of money and something like SK group would be more suitable or the entry level coilovers (buddyclub, super-street tein etc etc),
also from my experience 10/10 spring rate isn't too stiff for the street if they are in good built coilover, but i don't see why you would go out of your way to get that sort of spring rate or higher unless it was a good deal, or you wanted to go serious track action
Edited by [Michael]
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
