hello all.
i know it is a bit of a noob question but i really cant be stuffed trawling through all the turbo threads to find out the following question.
which standard nissan turbo's are the same output as the std series 2 stagea as well as being the same fittings etc., but with steel internals?
for instance does a snail from an r33 rb25 fit up the same? or perhaps and r34gtt etc?
and was wondering if the turbo from a dirty old holden VL is the same fitment but with steel internals as i have been told?
only reason i ask is i am wondering how long my original turbo will last if i wind it any further than the 12p.s.i i have it set at currently and have been told that a VL turbo would be a direct swap and has steel innards.
if that is true i can get hold of a pretty good vl unit for $150 andwould like to know if its gonna fit is all.
cheers oxford
https://www.sau.com.au/forums/topic/189801-what-std-nissan-turbos-match-up/
The VL turbo wont be roller bearing, nor will it be of comparable design as far as aerodynamics go. The trims are probably diferent on the housings and wheels too.
The turbo you have should last provided you dont have a crap boost controller that causes a boost spike to go over the 12psi. Around 14 is the absolute limit and above that your in the destruction zone.
i am running a turbosmart E-boost2 unit so it should hold no probs i just wanted to know the things outlined in the iniitial post but also how long would the wheels last if i were to run at 13-14psi?
also would i have to change anything to do with the wastegate settings or the blowoff valve etc?
turbos that i know for a FACT will bolt up to your stagea (becuase i have one of each at hte house)
r32
r33
r34
Y33 (VG30DET)
y32 (VQ30det)
stagea (obviously)
cefiro (refer to r32)
what are the relative differences in the units listed above if someone can answer?
for example are any of the steel internals as opposed to ceramic?
do they shift the rpm/boost band around either higher or lower, and if so which ones and which way specifically?
all this is in case mine goes tits up and i need to replace it quickly to return car to service, as iwould like to be able to have one ready to go if need be, and it would be a bonus if i didn't need to worry bout it smashing again if it were to be steel internals etc.
also wondering what a high flow would be worth to get done if i didn't need to do changeover?
cheers oxford
Edited by oxford1327
more or less, the R33 and R34 have ceramic turbines which are sensitive to temperature (and load). i presume much the same for the others however there are slight differences in the turbine housings. VG30 (single turbo) and R34 are the same size but compressors are different. R33 is slightly smaller turbine but same comp as the R34. (btw there are a few factory metal turbines but most are ceramic). the slightly larger turbine housing makes them a little more efficient and they MAY make about 10kw more due to slightly lower exhaust manifold pressure but maybe a hundred or two rpm slower to spool.
if you are going to change on the cheap, buy an R33 for a direct swap on a series 1 stagea or R34 turbo for a series 2.
generally prolonged loads over 12psi will lead to ceramic dust in the cat disease so leaning on the turbo harder is raising the risk. it might last 3 yrs it might last 5 minutes.
if you are looking to change then look at GCG hi-flows or HKS GT-RS as the cheapest (ballbearing) alternatives and onwards and upwards from there. remembering your old turbo is probably worth about $300.
Edited by wolverine
arent r33 turbos identical to s1 stageas?
i would be interested to try out a VG30det or VQ30det snail.
-Ryan
The s2 R33 turbo (and engine) is what we get in the s1 Stageas, and the R34 Neo engine is what goes in the s2 Stageas.
When my turbo blew on my s1, I replaced it with an s1 R33 turbo, which has steel wheels. I noticed that it didn't spool up quite as fast, not go quite as hard, but I've never bothered to check if the wastegate actuator had been fiddled with previously on the original one that was on my car.
The blown one is (obviously) on the right, and the replacement is on the left:
    • You have (externally anyway) a lot of patience!  At the very least your patience has rewarded you financially even if you decided you were over it!! I only just read your first experience of seeing the car, that would have been amazing!  Well documented too! It must be exciting knowing there's only 10 months left until you can get it on a boat and on it's way!!!???
    • Yeah, that's when. I guess you could say I'm as patient as I am foolish(or just a masochist?🤔). I've strongly considered throwing in the towel and calling it all quits many times, and have almost done so. It's a first-world problem for sure, but I've had a pretty rough go of it, as well as other factors; hoping something good comes of all this; it has to. It definitely is half the price of the ATS and performs great, but I'd like to try something different for once. I've sampled the ATS in a friend's 32 and it's solid👍
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
