Hey guys
Looking at putting coilovers on my car and i've noticed with the exception of tein (being a lil more) most coilover brands have the same features, claim to have the same abilities and are roughly the same price tag. How can you pick out the true high performing coilovers from the rest or are they all roughly going to give the same result.
If it helps my cars main application is street but i dont need coilovers for street. I need them to keep up and hopefully beat those damn evos' haha.
https://www.sau.com.au/forums/topic/189816-coilover-brands/
Hi there i dont know what car you have but mine is a R32 GTR and i just put ion a set of TEIN Mono flex and they are brilliant i have said before all my friends have been using Tein for street and track work and they are built well and reliable dont leak easily at all unless you mount a gutter or fly of the track at 120klms in grass and soil holes.
They run 7kg spring rate front and back and are comfortable but give your car rail handling OMG there good.
https://www.sau.com.au/forums/topic/189816-coilover-brands/#findComment-3422763
The one thing that coilover literature doesn't tell you, and what makes or breaks a coilover kit, is the performance of the dampers. They can crap on about how they're made (mono tube, inverted, whatever) but its the interplay between the spring and damper rates are what makes a car handle well in an initial impression (the construction and materials used will only really tell you how they'll last when hammered for a while).
The other thing is that suspension setup is very personal. Everyone's driving style is a little different, and so the feel you get from the car is also different. The only thing I can suggest is to try a couple of cars out with the parts you want, and see if you like it. That's what I did when I was shopping for coilovers for my car.
https://www.sau.com.au/forums/topic/189816-coilover-brands/#findComment-3423723
The reason for most people listing all the features now is everyone is about getting as many features for as little money as possible. In the end, you just get a shit damper, which in my opinion is the heart of a suspension system.
Do your research first and try and find out as much about the damper as possible. As a general rule of thumb, I will avoid any coilover kit under $1600 (ISC, D2, G4, HSD, etc), but that's just my opinion, a lot of people are quite content to run them and are happy with them. I drove with one of those brands and thought they were absolutely shit.
Spend as much as practical on your shocks and it will be a good base to work off of.
Edited by salad
https://www.sau.com.au/forums/topic/189816-coilover-brands/#findComment-3423832
I got the Bilsteins from Sydneykid's groupbuy, also have the "coilover conversion kit" with it.
oi Salad can you show us the "coilover conversion kit" is? WHere did you get it and how much? Im assuming that you are converting from Sk's blistein into a coilover? Effectiveness of it? Dollars saved?
Yudy
https://www.sau.com.au/forums/topic/189816-coilover-brands/#findComment-3424381
Same as the kit discussed in this thread
http://www.skylinesaustralia.com/forums/t188741.html
Bilstein make the kit, and then you can use any rectangular coil you want. Like the others, I've used Eibachs
Got the kit from the groupbuy, it costs another $1000 or so ontop of the original shocks.
I'm very happy with the results, and recommend the setup to everyone.
I think you'd be hard pressed to find another "coilover" that will be as good for the same sort of money.
Edited by salad
https://www.sau.com.au/forums/topic/189816-coilover-brands/#findComment-3424516
sp wat ypu have done is you bought Sk's blistein and adjusted it according to the grove?! And you are using Eiback springs for it instead of whiteline? That was actually what i wanted to in the first place but it will set me back 2ks for it from Sk. Where did you get the Eiback springs form?
https://www.sau.com.au/forums/topic/189816-coilover-brands/#findComment-3424552
What the coilover kit is, is a threaded sleave that sits on the circlip instead of a spring seat. Then there is a spring seat on the threaded sleave, so it is a threaded height adjustment.
I got the whole package from SK. I'm using Eibach coils instead of Whiteline because Whiteline dont make rectangular coils. At least not anymore anyway.
https://www.sau.com.au/forums/topic/189816-coilover-brands/#findComment-3424622
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
