ECU Reset?
The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes. United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows) -
Yep. And if you ever do, you'll just have to deal with it then.
E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane. -
Yeah i have R34 with factory small box and now RB25DET NEO swapoed and iam planning to upgrade to big box. So i would be good as long as i do not change diff?
