Hi all - can anyone tell me the type and capacity of gearbox oil my R32 GTS-4 requires?
I've been told that my box will take a lot more than a GTS-T and would require an oil suitable for the AWD setup…is that correct?
I've searched the forums around this and tried googling with no luck.
https://www.sau.com.au/forums/topic/189835-gts-4/
I used vmx80, and nulon g70 additive.
Same amount as a gtr box.
Others have used motul, or redline, search for their opinions on that topic.
*factory spec is 75-90 4.1l
transfer case uses atf. ~1.8l don't put gear oil in there.
Edited by heller44
https://www.sau.com.au/forums/topic/189835-gts-4/#findComment-3420714
Great, thanks for the info!
I've been searching a lot more and finally found this;
http://www.skylinesaustralia.com/forums/t40146.html
after searching for 'transfer case oil'.
So, the following is considered to be a Redline Shockproof product?
MT90 75W90 GL4Gearboxes calling for GL4 90W oil3.78Lts$128
I've been reading the Redline website - they seem to provide information regarding their 'Shockproof' range separately from their MT90 oils. It's all the same synthetic Shockproof oil right? Because I want to get this Redline Shockproof lightweight everyones talking about haha.
Last question, is the quality of the ATF important for Transfer cases? Should I get Redline ATF while I'm at it?
A lot of people here seem to go for the Nissan Matic-D or Castrol Synthetic Transmax Z (Matic-D approved?)
Edited by chestnut
https://www.sau.com.au/forums/topic/189835-gts-4/#findComment-3422176
Nissan matic d is the factory offering. That doesn't mean that you can't find options. Transmax z would appear to be an appropriate alternative.
Redline lightweight shockproof is what most people go for as a bandaid solution for crunching synchro's, usually 4th.
Unfortunately it is a GL5 oil that is not recommended due to being bad for the synchro material itself.
That is why I went for the vmx80 +g70 as 1) it is know to work, 2) vmx80 is a gl4, 3) vmx80 is a damn sight cheaper than redline..
There are loads more options for gearbox oil, have a read around about gearbox oil threads, specifically gtr boxes as yours is almost one, on forums here and overseas. Make up your own mind..
James.
https://www.sau.com.au/forums/topic/189835-gts-4/#findComment-3422408
Ok, so I need 75w-90 GL4? Are both gts-t and gts-4 boxes GL4?
vmx80 + g70 could be the go.
Is vmx80 a mineral oil like the VMX-M?
What if I used a full synthetic like Castrol Syntrans, could I use G70 with it...or is it not worth it if you go synthetic?
Edited by chestnut
https://www.sau.com.au/forums/topic/189835-gts-4/#findComment-3423002
    • Nah, I think the current user name suits me pretty well
    • Ooo, quite aggressive! I hope there'll be a professional taking photos on the trackday that you can get. Should look great there!
    • I think a lot of you hit the real issue, these brands aren't making cars at a competitive price. Lucky that Foxxconnnn didn't buy Nissan otherwise the cars would be built by 13 year olds doing 15 hour shifts like iPhones. This reminds me of British Leyland. 5th largest global manufacturer in 1968, collapsed by 1975 with only a couple of brands escaping to be owned by Chinese brands today. Along they way they vacuumed up MG, Jaguar, Daimler, Rover, Land Rover, Austin, Morris, Wolseley, Mini, Triumph, Riley, Alvis,  Yes, they had other problems but the basic issue was the wrong production (and therefore retail) price. If you are a car manufacturer and you haven't noticed China coming, its already too late.
    • Or the cistransgender
    • I can't help with the clearance question, I've always taken my machine shop's advice on that. It is worth considering that a shop that does that every day for road cars will be looking for as good as they can get off the shelf, not perfect. If you want more careful race style "blueprinting" then you need a race shop to measure/machine the engine. I do have an opinion on line boring the block though....don't do it unless you have to. The crank centre moves higher but the oil pump stays in the same place when you line bore the block.
