Installed this a while back.
The installation was REALLY easy, alot easier than what I have read on here.
Basicly you had to grind off one nut hole off the exhaust manifold where the heat sheld screws to and every thing else just bolts up.
Stock oil lines hocked up perfect and I just blocked off the water lines.
I didn't need to bend the actuator rod like some people have said.
Here are the results.
https://www.sau.com.au/forums/topic/189849-kkr480-on-r33-gtst/
I also run a kkr480 on my rb25det and me and a mate installed it ourselves,
turbo bolted up perfect, just had to grind a bit of the exhaust manifold, oil lines bolted up, but i went into enzed and for $30 or so he put new ends on my water lines to match the same size thats on the turbo, then i just chopped the lines and used high pressure/heat hose 2 move them around to fit nicely, and towed car to my mech 2 get dumpipe fab'd up and cooler piping change a little,
comes on hard bout 4000-4500rpm, i just run actuator spring which is bout 1.2-1.3 bar of boost, bit hard 2 control boost in these things, only downside..
but worth every penny, ive done bout 5000-7000kms alredy on this turbo, runs like a dream
Yeah it has got a GMC or some Aus turbo reco company bandged on it. I dont think its GMC but that just comes in to mind, its some 3 letter name.
Yeah KKR480s aren't that big, this one came off my VS commodore V6 and that spooled it at 2800rpm for 12psi. Its around 3000rpm, well you feel the boost kick in hard as then look at revs and its doing around 3000rpm. will have to have a closer look.
Its definarly a KKR480 I brought it new.
Any way stock turbo isn't big enough because I want 300RWKW.
Also I did lean the living daylights out of it early on to help turbo spool.
Well not that lean like 13.7:1 Air Fuel Mixture.
Edited by Finny
Yeah I would get a boost controller if I was you, adjusting that actuator rod would be a nightmare.
I didn't think you could get 1.2-1.3 bar out of the stock actuator as my commodore running stock actuator on the KKR480 only saw 12psi tops.
Does it over boost at all in high revs? I am hoping I dont need to get the wastegate cut out so it flows more.
Ummm the enzed bit makes no sence... KKR480s are oil only.. I just blocked off my water lines. The stock oil lines seemed to bolt up perfectly.
finny mate, you sure got a 480 cause no way it would spool up that early and also if its a oil only turbo then what are the other two fitting in the turbo core for????. you might have a bitsa turbo cause every 480 ive seen has oil and water fittings
Also you will be very lucky to get your 300kws with a kkr480 they arent bigger enough for it.
Edited by nick81xd
:S
Mine is from JustJap its marked as a JJR480 but I thought they where just rebadged KKR480s... they look identical.
Maybe I am wrong.
It has only got oil holes.
ummm that sucks... I should have got one from otomoto :)
KKR 480 =
Yes I can see the water holes on that one
JJR480 =
Ohh well looks like I will be going to a Garret GT35/40 later on down the track then.
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
