Cinching down the chin strap of his helmet, Toshio Suezaki's appearance transforms just before his thumb deploys the tidy flush-mounted door catch of the 2009 Nissan GT-R. The factory test driver is innocuous and soft-spoken, but in this moment his eyes harden. It is behind the wheel of this car, still camouflaged to frustrate spy shooters, that Suezaki-san will wield violence incongruous with his bookish manner just minutes later
More Info HERE?
  • Replies 59
thats a nice article mate..for me any car thats 1750kg (if you convert the weight they gave in pounds it makes this) is just way too heavy. sure its fast - but imagine how much faster it would be if it weighed like..1400kg....itd be incredible.
as it stands now it weighs more than an Audi A8...and thats just ridiculous...fair enough its not a stripped out sports car.but a car with 5 years of development with GTR heritage shouldnot weigh 1750kg..thats Sedan/Mercedes etc territory.
Thats the best inside scoop yet. Damn what an article.
It stripped the 911 by 2 seconds and that, in slightly damp conditions!
i loved the way the designer referred to it as a robot and that it was never meant to be beautiful but original and unique!
Btw i will be at the unveiling ( i live in tokyo ) so that will definitely be a buzz to remember...and sure to be busy as hell... :D:)
Edited by m3gtr
^^ WTF almost an r33? theres a couple of hundred KG difference u noob
thats a pretty funny comment considering the R35 will be bigger than a dodge viper...
hmmm... intrigued by that comment that the bare chassis weighs less than the 350Z's... so what's weighing it down? the AWD system? the heavily optioned interior? gonna be interesting to see how the car does on the track with that sorta chassis, and what the N1 version boasts, if they release one.
what exactly is a Premium Midship? thought it was an FR?
Lol I'm guessing once people go to DSG they wont ever want to go back to manual again.
Why would you want to go to manual? So you can push a clutch in? Why not use a system that is faster and will do everything that a manual does anyway only you dont have to worry about the clutch. Will make heel toeing a thing of the past :)
Why would you want to go to manual? So you can push a clutch in? Why not use a system that is faster and will do everything that a manual does anyway only you dont have to worry about the clutch. Will make heel toeing a thing of the past ;)
dont ever consider yourself a driver if you cant do it.
you seem to think DSG is going to take over the world.
driving a car is all about how involved you are. You advocating the DSG, not lamenting the loss of manual shifting shows me you may not care about being as involved as you can...
I demand you go out and rip out that power steering in your car... coz you know, real men have biceps of lumberjacks so that they can turn the steering wheel in a manner which is as involved in the driving experience as possible.
I don't understand why you keep saying DSG elimates heel toe? why would it? heel toe is just as valid with a DSG or other sequential box. and it's still useful.
drifters drive without power steering all the time here in japan . It increases the feel, not using a condom has the same effect.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
