Hey all,
Just finished reading the 'What should I get first?' thread: http://www.skylinesaustralia.com/forums/t45218.html
But what I'm asking is what I should do next, or what would you do next if you were in my position.
Okay, I've got a s2 R33 gtst, so far it has:
apexi fmic
3" exhaust (split dump pipe, 3" cat, 3" cat-back)
hd clutch
spitfire coils
k&n panel filter (tried running a POD, but saw better results with std airbox + panel)
I personally was thinking maybe a PowerFC or even a SAFC2. Or perhaps just a manual boost controller. However, if you think there are mods which will be give me equal or even better gains than these, then I'd prefer it, as my insurance co. (HBF) does not allow any sort of boost controller or replacement/piggyback ECU.
So... If you were me, performance wise what would you do next. Money isn't really an issue. I dont mean that as in I can buy anything. I mean it as in the more expensive the item is, the longer I will wait (and save up) for it.
Thanks heaps :D
https://www.sau.com.au/forums/topic/189893-need-some-advice/
or get a 10psi wastegate actuator from an r32, and get your standard computer remapped (i think dr drift can do 33's now), that way your insurance company will never know. also i would look into the suspension and brakes
Edited by Green_s13
I would get:
1) A new insurance company
2) New shocks/springs if not already replaced
3) Upgraded brake pads, maybe rotors (just on the fronts).
4) If you did 1), then whatever you like from here :) I'd say ECU/chip. You're in the same spot as me, only I've done 2) and 3) and boy do they make a difference.
Thanks for the replies so far guys.
Without a PowerFC/SAFC, i can't really expect to get more gains KW-wise, is that right?
I was planning to do the brakes/suspension anyway, so at this stage I'm really just interested in what would give me the best gains kw-wise.
yeha you're pretty stuffed if you can't get a powerfc or Tunable ECU unless you want to get a remap. BUt they aren't exactly as easily tunable as a powerfc.
www.justcars.com.au
www.shannonsinsurance.com.au
lol I don't know if they are the right links but you get the idea.
Yeah I think I might settle for an EBC + powerFC. I hear they are hard to come by (PowerFCs) as they are discontinued, i know someone who is selling it without the hand controller. This is still okay right? As I wouldnt change the settings on the controller anyway.
I took the car down to the tuners last week and I was told it was running 1 bar of boost (about 14 psi if im not mistaken) - how is this possible if my car has no electronic or manual boost controller? not sure if it has anything to do with my car running dangerously lean (it has since been fixed).
(Excuse my noobiness as I'm still trying to get my head around all of this)
Also, would you guys recommend putting in an aftermarket turbo in before an ECU. (Basically want to hold off getting an ECU for as long as possible due to insurance complications)
you'll be able to syphon more power out of a After market ECU and stock Turbo than a bigger turbo and stock ECU.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
