Hey guys,i was going to sell this car a while ago but i decided not to ecause i love it but due to circumstances changing and needind a family car it is up for sale again,but this time it has to go,along with my GTR.
I have a 1972 240z (2seater) it has an rb30 block that has been re-built just with linished std rods acl race bearings etc,head is a rb25det with the vvt deleted,it was re-built with stock cams 3 angle valve grind,new guides,arp studs etc.
It has a greddy plenum with xf tb
550 cc injectors with custom top feed rail and SX regulator
300-600 custom cooler
Garret GT35R with a 1.06 exh housing
Tial external gate with screamer
Microtech lt12-s with x-6 sequential ignition with bosch coils and magnicor leads
Turbosmart e-boost2 (sleeper series)
Custom 3" exhaust
Big radiator
VG30dett 5 speed(same as rb25 with better ratios)
Custom tailshaft
R32 lsd with custom en26 axels and V8 commodore cvs
Custom rear disk conversion
Autometer gauges
044 pump with surge tank etc
Electric water pump and thermo fan
I did the usual 1000 km run in then took the car to the dyno and made 320 hp @ the wheels on 10psi
the tuner told me it easily has potential to make 500+rwhp with more boost but to drive it for a while to get used to it first..
At the moment it is midway through being painted,i figure it is better to sell as is in primer so the new owner can choose the colour but if i cant sell it i will paint it then sell it.
I was driving this car to work ever day prior to taking it off the road for paint and it is a pretty good car to drive but to be honest it isnt really the type of car i would use as my only mode of transport.
This will be a really cool car when done and i hate to see it go but you gotta do what you gotta do.
It would benefit a lot from a roll cage which my engeneer has given the ok to put in on the street..The whole thing has gotten the nod from the engineer it just has to be taken to him once painted so he can write it all up..it is currently engineered with an rb20 so the rb30 is just an update on the current engeneers report.Unfortunatly i let it run out of rego a few months ago ut it will have no probs passing.plates come with it GTR 240
If you have a look around you will see that a standard 240z is worth 10-20k these days depending on condition so i am asking 13k but am open to offers..it owes me more than double that.will post better pics soon.
for more details pm or ring luke 0410497808
Edited by rbs30
https://www.sau.com.au/forums/topic/189913-240z-rb30det/
Like the car, but getting it to WA, and then licensing it would be very hard.
Good luck with the sale.
Hey mate, I'm in Perth ...can you PLEASE tell me ...what are my chances of getting THIS through WA pits?
http://www.skylinesaustralia.com/forums/t183521.html
Please let me know your thoughts ASAP!!
https://www.sau.com.au/forums/topic/189913-240z-rb30det/#findComment-3421208
What's the rust like? Rear tail lights, boot floor, sills?
Is there any knock in the tune?
What suspension is in it. What size are those wheels. Are you using nissan 4 pots on the front?
Cheers
It has had new floors,tail lights are good,rust been fixed in sills..small amount of rust in lh door.repacment skin can be bought from rare spares..
Knock in the tune?I dont understand why there would be any knock in the tune..if there was knock it wouldnt be tuned properly.
260z suspension with pedders gas shocks..the wheels are a whopping 14" and the brakes fit inside the by only millimeters..have toyota 4 pots for the front.direct bolt on to original mount
cheers
https://www.sau.com.au/forums/topic/189913-240z-rb30det/#findComment-3422532
I really like your car.
RE: the knock, 20ish is generally acceptable - was just asking if it was tuned proper.
I tried talking my cousin into buying it but he won't look at anything without a 350chev in it.
Good price for a rust free 240. 14's must be fun =D
https://www.sau.com.au/forums/topic/189913-240z-rb30det/#findComment-3422953
Thanks buddy.yep rust free 240's are definatly getting pretty pricey these days..(yep the 14's are a lot of fun lol)
what pistons you using in there?
the pistons are just rb30e's.just cast ones..prob 1 regret i do have is not putting forgies in but i didnt plan on going as far with it as i did..
https://www.sau.com.au/forums/topic/189913-240z-rb30det/#findComment-3426977
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
